.NET
Layer control in paperspace viewports with VB.net
2 REPLIES 2
Alainmorin
2250 Views, 2 Replies
Hi to all, any one have suggestions to, how to control existing layers (Freeze On/Off), in an existing viewports  (5 of them in Paperspace) in AutoCad Existing drawing with VB.net?  I just want to trigger On or Off, different layers in each different viewports.
Tags (1)
2 REPLIES 2
Hallex
in reply to: Alainmorin
Found this one in my codes, author unknown,
try it for current viewport in Paper space
    <CommandMethod("VpLayersMan")> _
        Public Sub TestLayerFreeze()
           '' add layer names to freeze/ thaw in paperspace viewports separated by commas
            Dim layers As List(Of String) = {"Wall", "ANNO-TEXT"}.ToList()''<-- layers for test
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = doc.Editor
            Dim db As Database = doc.Database
            Dim idLay As ObjectId
            Dim idLayTblRcd As ObjectId
            Dim lt As LayerTableRecord
            Dim layOut As Layout
            Dim tm As Autodesk.AutoCAD.ApplicationServices.TransactionManager = db.TransactionManager
            Dim ta As Transaction = tm.StartTransaction()
            Try
                Dim acLayoutMgr As LayoutManager
                acLayoutMgr = LayoutManager.Current
                Dim layDict As DBDictionary = DirectCast(ta.GetObject(db.LayoutDictionaryId, OpenMode.ForRead, False), DBDictionary)
                For Each itmdict As DBDictionaryEntry In layDict
                    layOut = DirectCast(ta.GetObject(itmdict.Value, OpenMode.ForRead, False), Layout)
                    ed.WriteMessage(vbLf + "Layout: {0}" + vbLf, layOut.LayoutName)
                    If layOut.LayoutName <> "Model" Then
                        acLayoutMgr.CurrentLayout = layOut.LayoutName
                        Dim ltt As LayerTable = DirectCast(ta.GetObject(db.LayerTableId, OpenMode.ForRead, False), LayerTable)
                        For Each lname As String In layers
                            idLay = ltt(lname)
                            lt = ta.GetObject(idLay, OpenMode.ForRead)
                            If ltt.Has(lname) Then
                                idLayTblRcd = ltt.Item(lname)
                            Else
                                ed.WriteMessage("Layer: """ + lname + """ not available")
                                Return
                            Dim idCol As ObjectIdCollection = New ObjectIdCollection
                            idCol.Add(idLayTblRcd)
                            ' Check that we are in paper space
                            Dim vpid As ObjectId = ed.CurrentViewportObjectId
                            If vpid.IsNull() Then
                                ed.WriteMessage("No Viewport current.")
                                Return
                            'VP need to be open for write
                            Dim oViewport As Viewport = DirectCast(tm.GetObject(vpid, OpenMode.ForWrite, False), Viewport)
                            If Not oViewport.IsLayerFrozenInViewport(idLayTblRcd) Then
                                oViewport.FreezeLayersInViewport(idCol.GetEnumerator())
                            Else
                                oViewport.ThawLayersInViewport(idCol.GetEnumerator())
                        Next
                Next
                ta.Commit()
            Finally
                ta.Dispose()
            End Try
        End Sub
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Alainmorin
Thank's Hallex, the problem I have is with this, is the viewport must be active to be able to freeze layers.  The drawings I have, have already viewport created (6 of them), and each one must have different frozen layer assign to it.  I must find a way to call viewport individually, and then change the required layer properties.
”Boost
