.NET
layer and LayerState Problem?
6 REPLIES 6
515 Views, 6 Replies
question 1:
I want turn on ,unlock,unfrozen all layer,the following is my code,but question is when run the code , the entity are all despeared, i have to regen the drawing and the entity could visible.
Database curdb;
Autodesk.AutoCAD.DatabaseServices.TransactionManager tm;
Transaction myT
curdb = Application.DocumentManager.MdiActiveDocument.Database;
tm = curdb.TransactionManager;
using (myT = tm.StartTransaction())
LayerTable lt = (LayerTable)tm.GetObject(curdb.LayerTableId, OpenMode.ForRead);
foreach (ObjectId objId in lt)
LayerTableRecord ltr = (LayerTableRecord)tm.GetObject(objId, OpenMode.ForWrite);
if (ltr.IsLocked) { ltr.IsLocked = false; }
if (ltr.IsFrozen) { ltr.IsFrozen = false; }
if (ltr.IsOff) { ltr.IsOff = false; }
myT.Commit();
question 2:
I can save layerstate,but I can't restore it, I wonder my problem is i don't know the use of parmeter: undefinedlayerstatepolicy. could anyone show me some code of how to use RestoreLayerState method in c#
6 REPLIES 6
one more question:
I read some post about problem of layer mananger command and vs 2005 ,but I still don't know how to fix it. could someone explain it in detail.
thanks in advance.
1. This is normal. Thawing a layer requires a regen. The layer command does
a regen (although an optimized one that only affects the objects on the
layers that are being thawed)
2.The following works fine for me:
LayerStateManager lsm =
Application.DocumentManager.MdiActiveDocument.Database.LayerStateManager;
//restore the On/Off state and Color
lsm.RestoreLayerState("test",ObjectId.Null,0,LayerStateMasks.On |
LayerStateMasks.Color);
wrote in message news:4856968@discussion.autodesk.com...
question 1:
Database curdb;
Transaction myT
OpenMode.ForRead);
myT.Commit();
question 2:
thanks.
1.my question is: does dot net api has a simliar method same as the method in activex ( Regen(AcRegenType.acActiveViewport) ) , I don't wish to use SendStringToExecute to do this.
2. for the second question , I have found the reason, because my code is converted from activex , in activex ,LayerStateMasks has a acAll enum, but in net api LayerStateMasks hasn't same one , so I have to combine all the enum to meet my need.
3. could you tell me how to fix the error in layer manager command?
1. No, the .net api doesn't have a regen but you can easily call the method
on the COM API.
3. You mean when running with .NET 2.0 Beta2? You need to bind acad back to
.net 1.1 (use acad.exe.config to do this). If you want to use .net 2.0
features then you are out of luck: you need to wait until the next .net 2.0
beta or ctp drop. (where they fixed the issue we are running into)
Albert
wrote in message news:4858285@discussion.autodesk.com...
thanks.
thanks albert.
yes, I use .net 2.0 beta,I am not famliar with acad.exe.config format ,could you explain in detail how to modify it?
acad.exe.config should look like this on your machine:
After following the instructions in the comment you should have something
like this:
wrote in message news:4859405@discussion.autodesk.com...
thanks albert.
”Boost
