.NET
.NET
Distinguished Contributor
3 Kudos
Post 1 of 5
Keep PaletteSet from Starting Docked
143 Views, 4 Replies
01-06-2006 11:55 AM
I am trying to stop my palette set from being docked upon startup. I cannot seem to get this...
PS = New PaletteSet("My Paletteset")
PS.Add("Test", New UltimateControl)
PS.Style = PaletteSetStyles.ShowAutoHideButton Xor PaletteSetStyles.Snappable
PS.MinimumSize = New System.Drawing.Size(250, 600)
PS.DockEnabled = DockSides.None
PS.Dock = DockSides.None
PS.Location = New System.Drawing.Point(20, 20)
PS.Visible = True
Ronnie Wilkins, Jr.
AMS CAD + CAFM Solutions
Sr. Solutions Developer
Autodesk Certified Instructor: Inventor
3 Kudos
Post 2 of 5
Re: Keep PaletteSet from Starting Docked
01-13-2006 11:38 AM in reply to: RonnieWilkins
Just an update...
It seams that I had to change a few lines of code around. But also had to show, hide, and then show again for the palette set to show correctly. If all I did was show the palette set, it came up garbled.
Ronnie Wilkins, Jr.
Member
0 Kudos
Post 3 of 5
03-15-2006 06:37 PM in reply to: RonnieWilkins
Could you specify what you did? Because i'm having the same issue.. Thanks
3 Kudos
Post 4 of 5
03-16-2006 11:01 AM in reply to: RonnieWilkins
The following code seemed to fix my issue, though the first time my palette is shown on a new install you must first resize manually if you have more than 4 tabs...I have no clue why.
PS = New AcWi.PaletteSet("My New Palette", New System.Guid("{E62F3B19-CD41-4814-A499-B2637A0090E7}"))
'Load a UserControl to the palette
Dim AutomatedShapesUC = New UIAutomatedShapes
PS.Add(AutomatedShapesUC.Text, AutomatedShapesUC)
PS.Style = AcWi.PaletteSetStyles.ShowAutoHideButton Xor AcWi.PaletteSetStyles.Snappable
PS.DockEnabled = AcWi.DockSides.None
PS.Visible = True
PS.Dock = AcWi.DockSides.None
PS.Visible = False
PS.Visible = True
Ronnie Wilkins, Jr.
Active Contributor
0 Kudos
Post 5 of 5
09-04-2006 07:19 AM in reply to: RonnieWilkins
This value:
Enables the forms location to be stored in the registry. Just make sure that you generate a new Guid so that no other progs mess with it.
