.NET
.NET
Valued Contributor
dynamicscope
Message 1 of 8 (1,381 Views)
Joining Entities (Arc, Line) with ObjectId
1381 Views, 7 Replies
07-30-2013 07:04 PM
I am trying to join multiple entities (Esoecially, Arc and Line).
I have there ObjectIds.
I know ARX 2011 and up provides the method called JoinEntity().
Unfortunately, I am using ARX 2007 and it does not provide such method.
I have searched the solution and I could only find the way to use "SendStringToExecute" and "_PEDIT" .....
Even with such approach there exists a problem.
I did...
SelectionSet ss = SelectionSet.FromObjectIds(ids);
Then I wanted to "_PEDIT" and select previous selection for Join.
But I cannot select the selection I created.
So my questions are the following.
1. Is there a way to join arc and line entities without sending command to the drawing?
2. If not (if sending command is the only way), how could I make the selection set as the previously selected entities?
FYI, I am using ObjectARX 2007 with C#
Does this blog post help ?
http://adndevblog.typepad.com/autocad/2012/05/converting-polyline-arc-to-acdbarc-and-vice-versa.html
From the arcs, the bulge values can be computed and used to create polyline arc segments.
Hallex
Message 2 of 8 (1,353 Views)
Re: Joining Entities (Arc, Line) with ObjectId
07-31-2013 03:57 AM in reply to: dynamicscope
This will get you started, then join all entities to polyline
      [CommandMethod("testJoinLines", "tjl", CommandFlags.Modal | CommandFlags.UsePickSet)]//OK
        public void TestConnectedLines()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            PromptEntityOptions pso = new PromptEntityOptions("\nPick a single line to join: ");
            pso.SetRejectMessage("\nObject must be of type Line!");
            pso.AddAllowedClass(typeof(Line), false);
            PromptEntityResult res = ed.GetEntity(pso);
            if (res.Status != PromptStatus.OK) return;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead) as BlockTableRecord;
                List<ObjectId> ids = JoinLines(btr, res.ObjectId);
                ObjectId[] lines = ids.ToArray();
                ed.SetImpliedSelection(lines);
                //or
                //ed.SetImpliedSelection(ids.OfType<ObjectId>().ToArray());
                PromptSelectionResult chres = ed.SelectImplied();
                if (chres.Status != PromptStatus.OK)
                    ed.WriteMessage("\nNothing added in the chain!");
                    return;
                foreach (SelectedObject selobj in chres.Value)
                    Entity subent = tr.GetObject(selobj.ObjectId, OpenMode.ForWrite) as Entity;
                    subent.ColorIndex = 4;
                tr.Commit();
        private void SelectConnectedLines(BlockTableRecord btr, List<ObjectId> ids, ObjectId id)
            Entity en = id.GetObject(OpenMode.ForRead, false) as Entity;
            Line ln = en as Line;
            if (ln != null)
                foreach (ObjectId idx in btr)
                    Entity ex = idx.GetObject(OpenMode.ForRead, false) as Entity;
                    Line lx = ex as Line;
                    if (((ln.StartPoint == lx.StartPoint) || (ln.StartPoint == lx.EndPoint)) ||
                        ((ln.EndPoint == lx.StartPoint) || (ln.EndPoint == lx.EndPoint)))
                        if (!ids.Contains(idx))
                            ids.Add(idx);
                            SelectConnectedLines(btr, ids, idx);
        public List<ObjectId> JoinLines(BlockTableRecord btr, ObjectId id)
            List<ObjectId> ids = new List<ObjectId>();
            SelectConnectedLines(btr, ids, id);
            return ids;
Valued Contributor
dynamicscope
Message 3 of 8 (1,298 Views)
08-12-2013 04:39 AM in reply to: Hallex
Thank you for the clue.
I tried this, but I am still stuck.
How do I join the entities?
I guess if they are only lines, I can just create a new polyline with every vertices of the lines.
But I have arcs as parts of the entities, I cannot just link as a polyline for an arc.
So this is what I tried...
ObjectId[] oIDs = oIDList.ToArray();
ed.SetImpliedSelection(oIDs);
PromptSelectionResult psr = ed.SelectImplied();
if (psr.Status == PromptStatus.OK)
	doc.SendStringToExecute("._PEDIT\n_m\n_p\n\n_y\n_join\n\n\n", true, false, false);
But the problem is I need to get the pointer to the object just joined.
The above clearly does not give me the joined object id.
Maybe, should I just go with ObjectAppended event?
Or is there any better way??
Hmmm......
To. Hallex
I wrote this response on Aug, 2nd. But it looks like it didn't get posted properly. :(
I have posted the new topic above on the same day.
Then last week (5~9), I was away from the town. So couldn't check the email.
If you have felt that I was ignoring your reponse, I am very sorry.
I just want to tell you I did not mean to do it.
Valued Contributor
dynamicscope
Message 4 of 8 (1,195 Views)
10-07-2013 11:36 PM in reply to: dynamicscope
Basically, I need to join a set of Arc and Line objects. Then I need the pointer (ObjectId) of the joined object for transformation. I still could not figure this out. :smileysad:
ADN Support Specialist
Balaji_Ram
Message 5 of 8 (1,150 Views)
10-11-2013 04:37 AM in reply to: dynamicscope
Balaji
Developer Technical Services
Autodesk Developer Network
Valued Contributor
dynamicscope
Message 6 of 8 (1,118 Views)
10-14-2013 02:15 AM in reply to: Balaji_Ram
Awesome~!!
I could create a new polyline with "Bulge"~!!!
For those who needs, this is the code to convert Arc to Polyline...
http://forums.autodesk.com/t5/NET/Convert-Arcs-to-Polylines/m-p/3072136/highlight/true#M24121
Thank you everyoene~!
New Member
ilnur2014
Message 7 of 8 (769 Views)
03-10-2014 12:44 AM in reply to: dynamicscope
Here is a working code. I apologize komentirovat code can not, do not know the English language. translated gugl.translate.
Net 3.5
P.S. I would be grateful if obnaruzhete mistake and let me know.
//Microsoft
using System;
using System.Collections;
using System.Collections.Generic;
using System.Linq;
//AutoCAD
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Colors;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
namespace Edit_Entity_AutoCad
    public class Edit_Entity : IExtensionApplication
        #region utility
        static public bool GetPoint(out Point3d point, string str)
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            PromptPointOptions ptopts = new PromptPointOptions(str);
            PromptPointResult ptRes = ed.GetPoint(ptopts);
            point = ptRes.Value;
            if (ptRes.Status == PromptStatus.Cancel)
                return false;
            else
                return true;
        static private Point3d PolarPoint(Point3d basept, Double angle, Double distance)
            return new Point3d(basept.X + distance * Math.Cos(angle),
                basept.Y + distance * Math.Sin(angle), basept.Z);
        static private Double Angle(Point3d start_pt, Point3d end_pt)
            double dx = Math.Abs(end_pt.X - start_pt.X);
            double dy = Math.Abs(end_pt.Y - start_pt.Y);
            if (end_pt.X < start_pt.X && end_pt.Y > start_pt.Y && dx != 0 && dy != 0)
                return Math.PI - Math.Atan(dy / dx);
            if (end_pt.X < start_pt.X && end_pt.Y < start_pt.Y && dx != 0 && dy != 0)
                return Math.Atan(dy / dx) + Math.PI;
            if (end_pt.X > start_pt.X && end_pt.Y < start_pt.Y && dx != 0 && dy != 0)
                return 2 * Math.PI - Math.Atan(dy / dx);
            if (end_pt.Y < start_pt.Y && dx == 0)
                return 1.5 * Math.PI;
            if (end_pt.X < start_pt.X && dy == 0)
                return Math.PI;
            return Math.Atan(dy / dx);
        static private Double Distance(Point3d start_pt, Point3d end_pt)
            return Math.Sqrt(Math.Pow(end_pt.X - start_pt.X, 2) + Math.Pow(end_pt.Y - start_pt.Y, 2));
        static private Double Distance(Point2d start_pt, Point2d end_pt)
        static private Double Distance(double delta_X, double delta_Y)
            return Math.Sqrt(Math.Pow(delta_X, 2) + Math.Pow(delta_Y, 2));
        static private double BulgeSegmentsPline(Point3d p1, Point3d p2, Point3d p3)
            if ((int) ScalarMultiplicationVectors(p2, p1, p2, p3) <= 0 && (int) MultiplicationVectors(p1, p3, p1, p2) == 0)
                return 0;
            Point2d tp;
            Point3d ph1 = PolarPoint(p1, Angle(p1, p2), 0.5 * Distance(p1, p2));
            Point3d ph2 = PolarPoint(p2, Angle(p2, p3), 0.5 * Distance(p2, p3));
            Inters_line(out tp, ph1, PolarPoint(ph1, 0.5 * Math.PI + Angle(p1, p2), 10), ph2, PolarPoint(ph2, 0.5 * Math.PI + Angle(p2, p3), 10), true);
            double alfa = AngleBetweenVectors(new Point3d(tp.X, tp.Y, 0.0), p1, new Point3d(tp.X, tp.Y, 0.0), p3);
            if ((MultiplicationVectors(p1, p3, p1, p2) * MultiplicationVectors(p1, p3, p1, new Point3d(tp.X, tp.Y, 0.0))) > 0)
                alfa = 2 * Math.PI - alfa;
            if (MultiplicationVectors(p1, p3, p1, p2) > 0)
                return Math.Tan(-0.25 * alfa);
            else
                return Math.Tan(0.25 * alfa);
        //косое произведение векторов
        static private double MultiplicationVectors(Point3d p1V1, Point3d p2V1, Point3d p1V2, Point3d p2V2)
            return (p2V1.X - p1V1.X) * (p2V2.Y - p1V2.Y) - (p2V2.X - p1V2.X) * (p2V1.Y - p1V1.Y);
        static private double MultiplicationVectors(Line vector1, Line vector2, double eps)
            Point3d p1V1 = vector1.StartPoint;
            Point3d p2V1 = vector1.EndPoint;
            Point3d p1V2 = vector2.StartPoint;
            Point3d p2V2 = vector2.EndPoint;
            double a = (p2V1.X - p1V1.X) * (p2V2.Y - p1V2.Y) - (p2V2.X - p1V2.X) * (p2V1.Y - p1V1.Y);
            if (Math.Abs(a) < eps)
                return 0.0;
            else
                return a;
        //скалярное произведение векторов
        static private double ScalarMultiplicationVectors(Point3d p1V1, Point3d p2V1, Point3d p1V2, Point3d p2V2)
            return (p2V1.X - p1V1.X) * (p2V2.X - p1V2.X) + (p2V1.Y - p1V1.Y) * (p2V2.Y - p1V2.Y);
        static private double ScalarMultiplicationVectors(Line vector1, Line vector2, double eps)
            double a = (p2V1.X - p1V1.X) * (p2V2.X - p1V2.X) + (p2V1.Y - p1V1.Y) * (p2V2.Y - p1V2.Y);
                return 0.0;
            else
                return a;
        #endregion
        private bool PolylineEqualsEntity(Transaction tr, ref Polyline pl,
            ref List<ObjectId> ss, List<ObjectId> ids, double eps)
            Plane pla = new Plane(new Point3d(0, 0, 0), new Vector3d(0, 0, 1));
            bool j = false;
                foreach (ObjectId id in ids)
                    Point3d pt1 = pl.GetPoint3dAt(0);
                    Point3d pt2 = pl.GetPoint3dAt(pl.NumberOfVertices - 1);
                    Curve ob = tr.GetObject(id, OpenMode.ForRead) as Curve;
                    if (ob == null || (ob as Entity).IsErased || ob.Closed == true ||
                          !(ob is Line) &&
                          !(ob is Arc) &&
                          !(ob is Polyline) &&
                          !(ob is Polyline2d)
                        ss.Remove(id);
                        continue;
                    #region "LINE,ARC"
                    if (ob is Line || ob is Arc)
                        if (Distance(pt1, ob.StartPoint) < eps)
                            pl.AddVertexAt(0, ob.EndPoint.Convert2d(pla), 0, 0, 0);
                            if (ob is Arc)
                                pl.SetBulgeAt(0, BulgeSegmentsPline(ob.EndPoint, ob.GetPointAtDist(0.5 * ob.GetDistanceAtParameter(ob.EndParam)), ob.StartPoint));
                            ob.UpgradeOpen();
                            ob.Erase(true);
                            ss.Remove(id);
                            j = true;
                            continue;
                        if (Distance(pt1, ob.EndPoint) < eps)
                            pl.AddVertexAt(0, ob.StartPoint.Convert2d(pla), 0, 0, 0);
                            if (ob is Arc)
                                pl.SetBulgeAt(0, BulgeSegmentsPline(ob.StartPoint, ob.GetPointAtDist(0.5 * ob.GetDistanceAtParameter(ob.EndParam)), ob.EndPoint));
                            ob.UpgradeOpen();
                            ob.Erase(true);
                            ss.Remove(id);
                            j = true;
                            continue;
                        if (Distance(pt2, ob.StartPoint) < eps)
                            pl.AddVertexAt(pl.NumberOfVertices, ob.EndPoint.Convert2d(pla), 0, 0, 0);
                            if (ob is Arc)
                                pl.SetBulgeAt(pl.NumberOfVertices-2, BulgeSegmentsPline(ob.StartPoint, ob.GetPointAtDist(0.5 * ob.GetDistanceAtParameter(ob.EndParam)), ob.EndPoint));
                            ob.UpgradeOpen();
                            ob.Erase(true);
                            ss.Remove(id);
                            j = true;
                            continue;
                        if (Distance(pt2, ob.EndPoint) < eps)
                            pl.AddVertexAt(pl.NumberOfVertices, ob.StartPoint.Convert2d(pla), 0, 0, 0);
                            if (ob is Arc)
                                pl.SetBulgeAt(pl.NumberOfVertices - 2, BulgeSegmentsPline(ob.EndPoint, ob.GetPointAtDist(0.5 * ob.GetDistanceAtParameter(ob.EndParam)), ob.StartPoint));
                            ob.UpgradeOpen();
                            ob.Erase(true);
                            ss.Remove(id);
                            j = true;
                            continue;
                    }//LINE, ARC
                    #endregion
                    if (ob is Polyline2d)
                        BlockTableRecord btr = tr.GetObject(Application.DocumentManager.MdiActiveDocument.Database.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                        Polyline2d pl2d = (Polyline2d) ob;
                        Polyline pl1 = new Polyline();
                        ObjectId id1;
                        pl2d.UpgradeOpen();
                        try
                            if (pl2d.PolyType != Poly2dType.CubicSplinePoly && pl2d.PolyType != Poly2dType.QuadSplinePoly)
                                pl1.ConvertFrom(pl2d, false);
                            id1 = btr.AppendEntity(pl1);
                            tr.AddNewlyCreatedDBObject(pl1, true);
                        catch
                            pl2d.Dispose();
                            pl1.Dispose();
                            ss.Remove(id);
                            continue;
                        if (pl1.NumberOfVertices != 0)
                            pl2d.Erase();
                            ss.RemoveAt(0);
                            if (pl1.Closed == true)
                                continue;
                            ob = tr.GetObject(id1, OpenMode.ForRead) as Curve;
                        else
                            pl2d.Dispose();
                            pl1.Dispose();
                            ss.Remove(id);
                            continue; ;
                    #region "POLYLINE"
                    if (ob is Polyline)
                            for (int i = 1; i < (ob as Polyline).NumberOfVertices; i++ )
                                pl.AddVertexAt(0, (ob as Polyline).GetPoint2dAt(i), 0.0, 0.0, 0.0);
                                pl.SetBulgeAt(0, -(ob as Polyline).GetBulgeAt(i - 1));
                            ob.UpgradeOpen();
                            ob.Erase(true);
                            ss.Remove(id);
                            j = true;
                            continue;
                            for (int i = (ob as Polyline).NumberOfVertices - 2; i >= 0; i--)
                                pl.SetBulgeAt(0, (ob as Polyline).GetBulgeAt(i));
                            ob.UpgradeOpen();
                            ob.Erase(true);
                            ss.Remove(id);
                            j = true;
                            continue;
                            for (int i = 1; i < (ob as Polyline).NumberOfVertices; i++)
                                pl.AddVertexAt(pl.NumberOfVertices, (ob as Polyline).GetPoint2dAt(i), 0.0, 0.0, 0.0);
                                pl.SetBulgeAt(pl.NumberOfVertices - 2, (ob as Polyline).GetBulgeAt(i - 1));
                            ob.UpgradeOpen();
                            ob.Erase(true);
                            ss.Remove(id);
                            j = true;
                            continue;
                                pl.SetBulgeAt(pl.NumberOfVertices - 2, -(ob as Polyline).GetBulgeAt(i));
                            ob.UpgradeOpen();
                            ob.Erase(true);
                            ss.Remove(id);
                            j = true;
                            continue;
                    }//POLYLINE
                    #endregion
                }//foreach
                    return j;
        private Point3dCollection SelectCrossingPolygonLEps(Point3d pt, double eps)
            Point3dCollection pc = new Point3dCollection();
            for (int i = 0; i < 8; i++)
                pc.Add(PolarPoint(pt, i * 0.25 * Math.PI, eps));
            return pc;
        private List<ObjectId> SelectAt2Point(List<ObjectId> ss, Point3d pt1, Point3d pt2, double eps)
            if (ss.Count == 0) return new List<ObjectId>();
            Editor editor = Application.DocumentManager.MdiActiveDocument.Editor;
            PromptSelectionResult Select;
            Select = editor.SelectCrossingPolygon(SelectCrossingPolygonLEps(pt1, eps));
            List<ObjectId> ss1 = new List<ObjectId>();
            if (Select.Status == PromptStatus.OK)
                IEnumerable<ObjectId> b = Select.Value.GetObjectIds().Cast<ObjectId>();
                ss1 = b.Where(id => ss.Contains(id)).Select(id => id).ToList<ObjectId>();
            Select = editor.SelectCrossingPolygon(SelectCrossingPolygonLEps(pt2, eps));
                foreach (ObjectId id in Select.Value.GetObjectIds())
                    if (ss.Contains(id) && !ss1.Contains(id))
                        ss1.Add(id);
            return ss1;
        [CommandMethod("jo")]
        public void jo()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor editor = doc.Editor;
            double eps = 0.001;
            Select = editor.GetSelection();
            SelectionSet acSSet;
            List<ObjectId> ss = new List<ObjectId>();
                acSSet = Select.Value;
                IEnumerable<ObjectId> b = acSSet.GetObjectIds().Cast<ObjectId>();
                ss = b.Select(id => id).ToList<ObjectId>();
            else
                editor.WriteMessage("\nОбъекты не выбраны!");
                return;
            ProgressBarClas form = null;
            if (ss.Count > 100)
                form = new ProgressBarClas();
                form.Max_volume = 100;
                form.Show();
                BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                int ssl = ss.Count;
                while (ss.Count != 0)
                    if (form != null)
                    form.Value = (int) (ssl - ss.Count) * 100 / ssl;
                    Polyline pl = new Polyline();
                    pl.SetDatabaseDefaults();
                    Curve ob = tr.GetObject(ss[0], OpenMode.ForRead) as Curve;
                          !(ob is Line) &&
                          !(ob is Arc) &&
                          !(ob is Polyline2d)
                        ss.RemoveAt(0);
                        continue;
                    pl.SetPropertiesFrom(ob);
                        if (ob is Arc)
                        ss.RemoveAt(0);
                        ob.UpgradeOpen();
                        ob.Erase(true);
                    if (ob is Polyline)
                        pl = ob as Polyline;
                        ss.RemoveAt(0);
                        if (pl.Closed == true)
                            continue;
                        ob.UpgradeOpen();
                        Polyline2d pl2d = (Polyline2d)tr.GetObject(ss[0], OpenMode.ForWrite);
                            pl.ConvertFrom(pl2d, false);
                        pl2d.Erase();
                        ss.RemoveAt(0);
                            continue;
                    List<ObjectId> ss1 = SelectAt2Point(ss, pl.GetPoint3dAt(0), pl.GetPoint3dAt(pl.NumberOfVertices-1), eps);
                    while (ss1.Count != 0)
                        if (PolylineEqualsEntity(tr, ref pl, ref ss, ss1, eps))
                            ss1 = SelectAt2Point(ss, pl.GetPoint3dAt(0), pl.GetPoint3dAt(pl.NumberOfVertices - 1), eps);
                        else
                            ss1.Clear(); ;
                    if (Distance(pl.GetPoint3dAt(0), pl.GetPoint3dAt(pl.NumberOfVertices - 1)) < eps)
                        pl.RemoveVertexAt(pl.NumberOfVertices-1);
                        pl.Closed = true;
                    if (!(ob is Polyline))
                        btr.AppendEntity(pl);
                        tr.AddNewlyCreatedDBObject(pl, true);
                tr.Commit();
            if (form != null)
                form.Close();
                form.Dispose();
            editor.WriteMessage("\n");
            //editor.Regen();
        }// function "jo"
        #region Initialize
        public void Initialize()
            editor.WriteMessage("Инициализация плагина.." + Environment.NewLine);
        public void Terminate()
        #endregion
    }//public class Entity_AutoCad : IExtensionApplication
New Member
ilnur2014
Message 8 of 8 (745 Views)
03-10-2014 11:28 AM in reply to: ilnur2014
Sorry for my English. I don't know him. I used google. Competently not be able to comment. If you find errors, please leave your comments. Thank you.
