.NET
jlsantiago
Message 1 of 3 (185 Views)
JLS3
185 Views, 2 Replies
03-30-2011 07:23 AM
How to get the ObjectId of an existing block in c#
Hetre is quick code hope this will  make a sence
 [CommandMethod("testblock")]
public static void TestBlocks()
string blockName = "dyn";
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
Database db = HostApplicationServices.WorkingDatabase;
Transaction tr = db.TransactionManager.StartTransaction();
using (tr)
try
BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
if (!bt.Has(blockName))
ed.WriteMessage("\nBlock \"{0}\" does not exist", blockName);
return;
ObjectId blkID = bt[blockName];
ed.WriteMessage("\nBlock \"{0}\" does exist, ObjectId is: {1}", blockName, blkID);
BlockTableRecord btr = tr.GetObject(bt[blockName], OpenMode.ForRead) as BlockTableRecord;
ObjectIdCollection blkRefIds = btr.GetBlockReferenceIds(true, false);
if (blkRefIds.Count == 0)
ed.WriteMessage("\nNo block instances \"{0}\" found", blockName);
return;
foreach (ObjectId brefId in blkRefIds)
BlockReference blkRef = (BlockReference)tr.GetObject(brefId, OpenMode.ForRead, false) as BlockReference;
ed.WriteMessage("\nBlock Reference \"{0}\" with ObjectID {1} found at position: {2}", blkRef.Name, brefId,blkRef.Position);
tr.Commit();//optional in this context
catch (Autodesk.AutoCAD.Runtime.Exception ex)
ed.WriteMessage(("AutoCAD Exception: " + ex.Message));
catch (System.Exception ex)
ed.WriteMessage(("Sytem Exception: " + ex.Message));
finally
// optional
~'J'~
Hallex
Message 2 of 3 (134 Views)
Re: JLS3
04-01-2011 12:06 AM in reply to: jlsantiago
Do you want to get ObjectId of BlockReferece (graphical instance of Block Definition)
 or of Block Definition itself?
There is a two different objects btw
Hallex
Message 3 of 3 (127 Views)
Re: JLS3
04-01-2011 12:41 AM in reply to: jlsantiago
             using (tr)
                 try
                         return;
                         return;
                 finally
                     // optional
~'J'~
