.NET
Active Contributor
jimmie_fulton
Message 1 of 2 (150 Views)
Jigs and Osnaps
150 Views, 1 Replies
08-01-2006 01:02 PM
I need to draw a polyline, with rubberbanding, and then do some other stuff with it, and then delete it. I'm using a Jig for this and it works well. I'm curious as to why I can't snap to other vertices of my polyline while drawing with the jig. I guess the polyline needs to be db resident? Or does it? If so, what is the best practices for drawing rubberbandable entities with a jig. Should I be adding the non-rubberbanding sections to the db immediately, instead of at the end of the operation?
*Tony Tanzillo
Message 2 of 2 (150 Views)
Re: Jigs and Osnaps
08-01-2006 03:03 PM in reply to: jimmie_fulton
Your guess is right. I'm pretty sure that the PLINE command
does something like what you describe (adds the polyline to
the database and updates it on new vertex you pick).
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5255354@discussion.autodesk.com...
Announcements
Need installation help?
