Show only
Search instead for
Well, I finally figured out how to jig a table, guess I'm the only one
who ever wanted to do this.
Even though a Table is a block, the constructors are different. The
table has to be created in the jig class constructor. You cant just pass
in a block table record of a table like you can with a block.
Anyways, heres the simplified version of my code in case there is one
other person on the planet who wants to do this...
using System;
using System.Collections.Generic;
using System.Text;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.ApplicationServices;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
