.NET
Distinguished Contributor
0 Kudos
Post 1 of 3
Jig pline flash
109 Views, 2 Replies
05-28-2007 06:37 PM
I use jig in one of application to draw pline. it works fine on my machine. but my customer report it flash slowly. I can not repeat it on my machine. Does anybody has the same problem? if yes, how do you make it fast?
I really appreciate your help. Thank you very much.
Wes
Vault Pro 2014, Windows 7 64 bit, AutoCAD (ACA, Map) 2014
0 Kudos
Post 2 of 3
Re: Jig pline flash
06-06-2007 06:56 AM in reply to: wesbird
Update:
e.g. if we a pline, when you start draw any vertex after the 3rd, when you move mouse around, only you can see the first 2 segentment. the others segement will apprear until mouse stop move. I can not repeat this on my machine.
I check the monitor setting, it's fine.
to figure out what's wrong there, we set up remove desktop. The most weird is, when I take the control from my machine to control the remote machine, jig is much better.
What could be the reason? the mouse ?
Do you have any advice so I can solve this problem?
Thank you and I appreciate your time
Wes
New Member
0 Kudos
Post 3 of 3
Re: Jig pline flash
09-11-2007 07:46 PM in reply to: wesbird
Hi,weslley, I use jig to draw pline, too. But the code seems exist some problem. I lost in the middle.So could you post your code which draw pline let me study if is OK.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
