.NET
Jig pline flash
2 REPLIES 2
wesbird
196 Views, 2 Replies
Jig pline flash
I use jig in one of application to draw pline. it works fine on my machine. but my customer report it flash slowly. I can not repeat it on my machine. Does anybody has the same problem? if yes, how do you make it fast?
I really appreciate your help. Thank you very much.
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
2 REPLIES 2
wesbird
in reply to: wesbird
Update:
e.g. if we a pline, when you start draw any vertex after the 3rd, when you move mouse around, only you can see the first 2 segentment. the others segement will apprear until mouse stop move. I can not repeat this on my machine.
I check the monitor setting, it's fine.
to figure out what's wrong there, we set up remove desktop. The most weird is, when I take the control from my machine to control the remote machine, jig is much better.
What could be the reason? the mouse ?
Do you have any advice so I can solve this problem?
Thank you and I appreciate your time
Wes
elixir
Hi,weslley, I use jig to draw pline, too. But the code seems exist some problem. I lost in the middle.So could you post your code which draw pline let me study if is OK.
”Boost
