.NET
Valued Contributor
wbdehaan
Message 1 of 9 (477 Views)
Iterating trough items in block
477 Views, 8 Replies
02-16-2012 01:56 AM
at multiple places i have drawn the same block in a drawing, and i would like select one block in the drawing, then iterate through the items in the block, and find the actual coordinates of a 3d-polyline (that is drawn in that block) in modelspace. How can I do this?
kind regards,
Wouter de Haan
the Netherlands
Here you go, tested on A2009 only
{code}
  Public Shared Function GetAllVertices(ent As Polyline) As Point3dCollection
   Dim points As New Point3dCollection()
   Dim pt As New Point3d()
   Dim i As Integer = 0
   For i = 0 To ent.NumberOfVertices - 1
    pt = ent.GetPoint3dAt(i)
    points.Add(pt)
   Next
   Return points
  End Function
  <CommandMethod("Gnp")> _
  Public Shared Sub TestSubEntity()
   Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
   Dim db As Database = doc.Database
   Dim ed As Editor = doc.Editor
   Dim ucs As Matrix3d = ed.CurrentUserCoordinateSystem
   Dim tr As Transaction = db.TransactionManager.StartTransaction()
   Try
    Using tr
     Dim pno As New PromptNestedEntityOptions(vbLf & "Select Nested Polyline >>")
     pno.AllowNone = False
     Dim rs As PromptNestedEntityResult = ed.GetNestedEntity(pno)
     If rs.Status <> PromptStatus.OK Then
      Return
     End If
     Dim entId As ObjectId = rs.ObjectId
     Dim selent As Entity = TryCast(tr.GetObject(entId, OpenMode.ForWrite), Entity)
     Dim ids As ObjectId() = rs.GetContainers()
     Dim blkId As ObjectId = ids(0)
     If blkId.IsNull Then
      Return
     End If
     Dim blkEnt As Entity = TryCast(tr.GetObject(blkId, OpenMode.ForRead), Entity)
     If blkEnt Is Nothing Then
      Return
     End If
     Dim bref As BlockReference = TryCast(blkEnt, BlockReference)
     If bref Is Nothing Then
      Return
     End If
     Dim mat As Matrix3d = bref.BlockTransform
     Dim btrec As BlockTableRecord = TryCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
     Dim pline As Polyline = TryCast(selent, Polyline)
     If pline Is Nothing Then
      Return
     End If
     Dim circ As Circle
     Dim points As Point3dCollection = GetAllVertices(pline)
     For i As Integer = 0 To points.Count - 1
      Dim p As Point3d = points(i)
      circ = New Circle(p.TransformBy(mat), Vector3d.ZAxis, 0.1)
      btrec.AppendEntity(circ)
      tr.AddNewlyCreatedDBObject(circ, True)
     Next
     tr.Commit()
    End Using
   Catch ex As Autodesk.AutoCAD.Runtime.Exception
    ed.WriteMessage(ex.Message + vbLf + ex.StackTrace)
   Finally
   End Try
  End Sub
{code}
~'J'~
Hallex
Message 2 of 9 (473 Views)
Re: Iterating trough items in block
02-16-2012 02:26 AM in reply to: wbdehaan
Take a look at GetNestedEntity method of Document Editor
What is the language you prefer C# /  VB.NET?
~'J'~
Valued Contributor
wbdehaan
Message 3 of 9 (467 Views)
02-16-2012 03:29 AM in reply to: Hallex
Thanks for your reply,
where can I find the 'document editor' ? I use Visual Studio 2008 (vb.net)
Wouter
Alfred.NESWADBA
Message 4 of 9 (464 Views)
02-16-2012 03:49 AM in reply to: wbdehaan
for your currentlyy opened DWG:
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MDIActiveDocument.Editor
- alfred -
Alfred NESWADBA
Hallex
Message 5 of 9 (456 Views)
02-16-2012 06:05 AM in reply to: wbdehaan
{code}
    points.Add(pt)
   Next
   Return points
  End Function
   Try
    Using tr
      Return
     End If
      Return
     End If
      Return
     End If
      Return
     End If
      Return
     End If
     Dim circ As Circle
     Next
     tr.Commit()
    End Using
   Finally
   End Try
  End Sub
{code}
~'J'~
Valued Contributor
wbdehaan
Message 6 of 9 (424 Views)
02-17-2012 07:18 AM in reply to: Hallex
Thank you very much for this code, it works!
kind regards
Wouter
Hallex
Message 7 of 9 (418 Views)
02-17-2012 09:45 AM in reply to: wbdehaan
You're welcome, Wouter
Cheers :smileyhappy:
~'J'~
Valued Contributor
wbdehaan
Message 8 of 9 (387 Views)
02-20-2012 01:27 AM in reply to: Hallex
In addition, i have another question.
i want to make an adjustment to the supplied code, and therefore i need to step through all objects in the block, but since i am new to .net i cannot get it to work. How can i step through all the objects in the selected block?
Wouter
Hallex
Message 9 of 9 (372 Views)
02-20-2012 06:30 AM in reply to: wbdehaan
Wouter,
Here ya go
This crappy code of mine is based on Tony Tanzillo's idea that  I did find on this forum
ss give that a try
{code}
 _______________________________________
        <CommandMethod("GAS")> _
        Public Shared Sub GetAllSubentitiesTest()
            Dim sb As New StringBuilder
            Try
                Dim pso As New PromptEntityOptions(vbCr & "Select a Block Reference: ")
                pso.SetRejectMessage(vbLf & " Select  a Block Reference only!")
                pso.AddAllowedClass(GetType(BlockReference), False)
                Dim psr As PromptEntityResult = ed.GetEntity(pso)
                If psr.Status <> PromptStatus.OK Then
                    Return
                End If
                Using tr As Transaction = db.TransactionManager.StartTransaction
                    Dim ent As Entity = DirectCast(tr.GetObject(psr.ObjectId, OpenMode.ForRead), Entity)
                    Dim bref As BlockReference = DirectCast(ent, BlockReference)
                        Return
                    Else
                        bref.UpgradeOpen()
                    End If
                    Dim btr As BlockTableRecord = TryCast(tr.GetObject(bref.BlockTableRecord, OpenMode.ForRead, False), BlockTableRecord)
                    If btr Is Nothing Then
                        Return
                    End If
                    Dim expIds As New DBObjectCollection
                    bref.Explode(expIds)
                    If expIds.Count > 0 Then
                        For i As Integer = 0 To expIds.Count - 1
                            Dim obj As Entity = TryCast(expIds(i), Entity)
                            If obj IsNot Nothing Then
                                If Not obj.IsWriteEnabled Then
                                    obj.UpgradeOpen()
                                    obj.TransformBy(bref.BlockTransform) '<-- to get right geometric properties
                                End If
                                sb.AppendLine(String.Format("{0}" + vbTab + "{1}" + vbLf, obj.GetRXClass().Name, obj.GetRXClass().DxfName))
                                obj.Dispose()
                            End If
                        Next
                    End If
                    bref.DowngradeOpen()
                End Using
            Catch ex As System.Exception
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message & vbCr & ex.StackTrace)
            Finally
                If sb.ToString <> String.Empty Then
                    MsgBox(sb.ToString)
                End If
            End Try
        End Sub
{code}
~'J'~
