First I assume that this is the best way to loop through the open
documents in a session?
Dim docs As DocumentCollection
Dim doc As Document
docs = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
For Each doc In docs
' do stuff
Next
During this process, the *doc* appears to contain the majority of
sysvars but DBMOD is missing and I don't see a IsModified either.
I can use COM and .GetVariable, but in the status line at the bottom,
AutoCAD appears to be switching to the document and when you have a lot,
it slows it down considerable and has a lot of 'visual noise'.
So whats the best way to determine DBMOD status?
Thanks in advance,
Terry
