.NET
Iterating documents and determining if its modied using vb.net ?
4 REPLIES 4
274 Views, 4 Replies
First I assume that this is the best way to loop through the open
documents in a session?
Dim docs As DocumentCollection
Dim doc As Document
docs = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
For Each doc In docs
' do stuff
Next
During this process, the *doc* appears to contain the majority of
sysvars but DBMOD is missing and I don't see a IsModified either.
I can use COM and .GetVariable, but in the status line at the bottom,
AutoCAD appears to be switching to the document and when you have a lot,
it slows it down considerable and has a lot of 'visual noise'.
So whats the best way to determine DBMOD status?
Thanks in advance,
Terry
4 REPLIES 4
jbooth
Are you sure DBMOD is a document level variable, and not an application level variable?
Try using Application.GetSystemVariable(), instead of using the DocumentManager.
This is just a guess.
How can that be, if its value reflects if a given
document has been modified?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
ChrisArps
It sort of works because it is referring to the "current" document. So he is back to the slow switching of the documents again.
I wonder if there is a technical reason that this was omitted from the dotnet document object or was it just an oversight?
Chris Arps
Yes, it returns the value for the current document,
and that means it is not an application-level state.
I don't know why DBMOD was not floated at the
document/database level.
wrote in message news:5146464@discussion.autodesk.com...
Chris Arps
”Boost
