.NET
New Member
maxime.didaoui
Message 1 of 4 (694 Views)
Iterating block (block in a block) in C#
694 Views, 3 Replies
04-18-2013 02:24 AM
Hi everyone,
I'm a french dude so sorry if my English isn't well enough.
I'm new with AutoCAD (2012) and I'm trying to create a commandmethod which allow to select and see what's in the block selected.
I already looked some forums but they used the database instead of the promptselection.
- http://forums.autodesk.com/t5/NET/simple-example-of-iterating-a-collection-eg-blocks/td-p/2553278
- http://forums.autodesk.com/t5/NET/How-to-iterate-through-items-of-a-block-reference-in-Dotnet/m-p/...
This is my code:
   [CommandMethod("SelectBlock")]
        public void SelectBlock()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            Database db = HostApplicationServices.WorkingDatabase;
            Transaction tr = db.TransactionManager.StartTransaction();
           try
                PromptSelectionOptions opts = new PromptSelectionOptions();
                opts.MessageForAdding = "Select block references:";
                PromptSelectionResult res = ed.GetSelection(opts);
                if (res.Status != PromptStatus.OK){return;}
                 SelectionSet selSet = res.Value;
                 ObjectId[] ids = selSet.GetObjectIds();
                 foreach (ObjectId blkId in ids)
                   if (blkId != null)
                       // Open the Block table record Model space for read
                       BlockTableRecord acBlkTblRec = tr.GetObject(blkId, OpenMode.ForRead) as BlockTableRecord;
                        //acBlkTblRec is still null
// Step through the Block table record
if (acBlkTblRec != null) { foreach (ObjectId asObjId in acBlkTblRec) { Entity e = (Entity)tr.GetObject(asObjId, OpenMode.ForRead); ed.WriteMessage(e.ToString()); } } } } tr.Commit(); } catch (Autodesk.AutoCAD.Runtime.Exception ex) { ed.WriteMessage(("Exception: " + ex.Message)); } finally { tr.Dispose(); } } } }
 Everything is fine until the bold line. In fact, I find the block selected (it contains 4 blocks) and go inside the first foreach, but when I instantiate my BlockTableRecord, acBlkTblRec stay "null" and the second foreach is ignored. Do you have any idea about what happended ?
I use AutoCad 2012 and Visual Studio 2010.
Thank you in advance for your precious help :cathappy:
Max
Valued Contributor
fsztuczny
Message 2 of 4 (689 Views)
Re: Iterating block (block in a block) in C#
04-18-2013 02:46 AM in reply to: maxime.didaoui
Hi
1. Not if (blkId != null), should be:
if ( !blkid.IsErased )
2. Not BlockTableRecord acBlkTblRec = tr.GetObject(blkId, OpenMode.ForRead) as BlockTableRecord; should be:
BlockReference blRef = tr.GetObject( blkId, OpenMode.ForRead ) as BlockReference;
if( blRef != null )
or
Entity ent = tr.GetObject(blkId, OpenMode.ForRead) as Entity;
if( ent.GetType() == typeof( BlockReference ) )
BlockReference blRef = ent as BlockReference;
//Now you can open BlockTableRecord:
BlockTableRecord acBlkTblRec = tr.GetObject( blRef.BlockTableRecord, OpenMode.ForRead ) as BlockTableRecord
_gile
Message 3 of 4 (661 Views)
Re : Iterating block (block in a block) in C#
04-18-2013 05:49 AM in reply to: maxime.didaoui
Salut,
Il semble que tu ne connaisse pas bien la différence entre une définition de bloc (BlockTableRecord) et une référence de bloc (BlockReference).
Une définition de bloc est un objet "non graphique" stocké dans la table des blocs (BlockTable) qui est une sorte de collection d'entités (les espaces objet et papier sont aussi de type BlockTableRecord).
Une référence de bloc est une représentation géométrique (entité graphique) d'une définition de bloc. Elle est insérée dans un espace objet ou papier ou dans une autre définition de bloc (un objet de type BlockTableRecord).
Quand on sélectionne un bloc dans le dessin, c'est une référence de bloc qu'on sélectionne et on peut pas accéder directement aux entités composant ce bloc. On n'y accède que par la définition du bloc.
            using (Transaction tr = db.TransactionManager.StartTransaction())
                // A selection filter to select only block references
                SelectionFilter filter = new SelectionFilter(
                    new TypedValue[1] { new TypedValue(0, "INSERT") });
                if (res.Status != PromptStatus.OK) { return; }
                    if (blkId != null)
                        // Open the Block reference for read (no need for type checking because as the selection filter did it)
                        BlockReference acBlkRef = (BlockReference)tr.GetObject(blkId, OpenMode.ForRead) as BlockReference;
                        // Open the Block table record of the selected reference for read
                            (BlockTableRecord)tr.GetObject(acBlkRef.BlockTableRecord, OpenMode.ForRead);
                        ed.WriteMessage("\n\n{0}", acBlkRef.Name);
                            ed.WriteMessage("\n{0}", e);
                tr.Commit();
Gilles Chanteau
New Member
maxime.didaoui
Message 4 of 4 (603 Views)
05-02-2013 06:55 AM in reply to: _gile
Salut Gile,
Merci pour cette réponse détaillée, je pense avoir maintenant saisi la différence, et ça marche à merveille.
Je vais continuer de me documenter là dessus.
And I would like to thank you too fsztuczny, it works now.
Maxime
