<CommandMethod("IterateSetups")> _ Public Sub IteratePageSetups() '' Get the current document and database, and start a transaction Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' This example returns the PageSetup table for the current database Dim acPltDic As DBDictionary acPltDic = acTrans.GetObject(acCurDb.PlotSettingsDictionaryId, _ OpenMode.ForRead) '' Step through the PageSetup table and print each PageSetup name For Each acObjId In acPltDic Dim acPlotSet As PlotSettings acPlotSet = acTrans.GetObject(acObjId, OpenMode.ForRead) acDoc.Editor.WriteMessage(vbLf & acPlotSet.PlotSettingsName) Next '' Dispose of the transaction End Using End Sub
What's the sub object for a PlotSettings Dicitionary here? I'm just trying to iterate through them.
Okay so I Figured out the object I needed
Dim acPltDicEntry As DBDictionaryEntry
In business:
<CommandMethod("its")> _ Public Sub IteratePage() '' Get the current document and database, and start a transaction Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' This example returns the PageSetup table for the current database Dim acPltDic As DBDictionary Dim acPltDicEntry As DBDictionaryEntry Dim acPageSetup As PlotSettings acPltDic = acTrans.GetObject(acCurDb.PlotSettingsDictionaryId, _ OpenMode.ForRead) '' Step through the PageSetup table and print each PageSetup name Dim objId As ObjectId For Each acPltDicEntry In acPltDic MsgBox("Key: " & acPltDicEntry.Key) 'Get PageSetup ObjId = acPltDic.GetAt(acPltDicEntry.Key) acPageSetup = objID.GetObject(OpenMode.ForRead) MsgBox("Pagesetup: " & acPageSetup.PlotSettingsName) Next '' Dispose of the transaction End Using End Sub
Maybe this will help someone else.
