.NET
.NET
Distinguished Contributor
5 Kudos
Post 1 of 5
Iterate Through Raster Images/Image Dictionary
327 Views, 4 Replies
02-28-2012 11:44 AM
Here's the Code I have so far:
I want to iterate through the Image Dictionary and Connect into the Raster ImageDef Properties.
I want to be able to modify and fix missing Raster Images.
Can someone help me get this code sorted out.
For Each myObjID As ObjectId In myModelSpace
                Dim myEnt As Entity = myObjID.GetObject(OpenMode.ForRead)
If TypeOf myEnt Is Image Then
                        Dim myRasterImg As RasterImage
                        Dim myRasterImgDef As RasterImageDef
                        'Open The Dictionary
                        Dim ImgDict As ObjectId = RasterImageDef.GetImageDictionary(DatabaseIn)
                        For Each dictEntry In ImgDict
                        Next
End If
assuming transaction "avctivetx" is started
For Each dicentry As DBDictionaryEntry In imageDict
            Dim rasterimgDef As RasterImageDef = CType(activetx.GetObject(CType(dicentry.Value, ObjectId), OpenMode.ForRead), RasterImageDef)
            msg = msg & rasterimgDef.ActiveFileName & vbCrLf
        Next
Never mind...
Found it
 ElseIf TypeOf myEnt Is Image Then
'Database Image Attachment
Dim myExtImage As New extractRasterImage
Dim myRasterImage As RasterImage = CType(myTrans.GetObject(myEnt.ObjectId, OpenMode.ForRead), RasterImage)
Dim myRasterImageDef As RasterImageDef = CType(myTrans.GetObject(myRasterImage.ImageDefId, OpenMode.ForRead), RasterImageDef)
myExtImage.Path = myRasterImage.Path
myExtImage.ActiveFullFileName = myRasterImageDef.ActiveFileName
MsgBox(myRasterImage.Path & myRasterImageDef.ActiveFileName)
myExtractedDB.RasterImages.Add(myExtImage)
Valued Mentor
30 Kudos
Post 2 of 5
Re: Iterate Through Raster Images/Image Dictionary
02-28-2012 12:21 PM in reply to: VB_Autocad_guy
        Next
5 Kudos
Post 3 of 5
02-28-2012 01:31 PM in reply to: fieldguy
How would I get the RasterImageDef and it's attached properties?
                    MsgBox(myRasterImage.Path)
5 Kudos
Post 4 of 5
02-28-2012 01:36 PM in reply to: VB_Autocad_guy
If anyone's wondering this is how I got it to work.
   'Start(Transaction)
        Using myTrans As Transaction = DatabaseIn.TransactionManager.StartTransaction
            'Take a Look at Attachments
            Dim nod As DBDictionary
            Dim imageDict As DBDictionary
            nod = CType(myTrans.GetObject(DatabaseIn.NamedObjectsDictionaryId, OpenMode.ForRead, False), DBDictionary)
            imageDict = CType(myTrans.GetObject(nod.GetAt("ACAD_IMAGE_DICT"), OpenMode.ForRead, False), DBDictionary)
            Dim msg As String = ""
                Dim myRasterImgDef As RasterImageDef = CType(myTrans.GetObject(CType(dicentry.Value, ObjectId), OpenMode.ForRead), RasterImageDef)
                msg = (msg & myRasterImgDef.ActiveFileName & vbTab & myRasterImgDef.FileType & vbCr & _
                            vbTab & myRasterImgDef.SourceFileName & vbCrLf)
            Next
            MsgBox(msg)
5 Kudos
Post 5 of 5
02-28-2012 01:46 PM in reply to: VB_Autocad_guy
Never mind...
Found it
