.NET
Issues with PublishDSD
6 REPLIES 6
csludtke
1613 Views, 6 Replies
Background
Our company places multiple blocks per layout (and even Model Space).   These blocks represent drawing formats.  It is not uncommon to have 50 sheets per layout.
8 years ago (AutoCAD 2006), I created a utility using .Net that  leveraged the plotting engine to create the appropriate PostScript and used GhostScript to obtain a multi-sheet .pdf file.  Note that the multi-sheet pdf file contains sheets of different sizes.
It has worked great for 6 years. The pdf files were not "Feature Rich".   User complaints  related to search functionality and imbedded layer information were present.
We are upgrading to AutoCAD 2013.  I have spent the past 4 days upgrading that solution.   Here is what I have done.
I have a solution that creates a Page Setup for  each page.  After these page setups are created, I am able to manually use them to create individual pdf files.  I am also able to programically create individual  PDF's via the PlottingServices.PlotEngine.
I have created DSD files using  two methods (compiling via DsdEntryCollection, etc,and via direct text tile).
When using Application.Publisher.PublishDsd(..) method, I get an error via the publishing log
  Job: - Error(s) Did Not Plot
Job ID: 1
Sheet set name: SheetSetName Set for DWG No 2219679 : 4 Sheets - Publish via ACAD pdf
Date and time started: 8/13/2013 3:05:58 PM
Date and time completed: 8/13/2013 3:05:59 PM
UserID: csludtke
Profile ID: <<ACADMPP>>
Total sheets: 0
Sheets plotted: 0
Number of errors: 0
Number of warnings: 0
ERROR: Error
Subsequently, (using the same DSD) I manually (publish on the command line) load the dsd file:
I select 'Replace all sheets in the list"
I then click on "Publish" and I obtain the output that I want.
Here is a segment of the "PublishDSD" code.
  Sheet: Size E Sheet 1 - Plotted
File: C:\temp\test3.dwg
Category name:
Page setup: BATC FS PDF SH 01
Device name: DWG To PDF.pc3 - plotted to file
Plot file path: C:\temp\test3.pdf
Paper size: ANSI E (44.0 x 34.00 Inches)
Sheet: Size E Sheet 2 - Plotted
Category name:
Page setup: BATC FS PDF SH 02
Sheet: Size E Sheet 3 - Plotted
Category name:
Page setup: BATC FS PDF SH 03
Sheet: Size E Sheet 4 - Plotted
Category name:
Page setup: BATC FS PDF SH 04
Does anyone have a vb example using PublishDSD?
        Try
            WriteDSD()
            Dim CurrAcadDoc As Document = Application.DocumentManager.MdiActiveDocument
            Dim CurrAcadDB As Database = CurrAcadDoc.Database
                Using DSDDataFile As New DsdData
                    Using PPD As PlotProgressDialog = New PlotProgressDialog(False, my_PresentFormats.BaseCollection.Count, True)
                        PPD.PlotMsgString(PlotMessageIndex.DialogTitle) = "PDF Creation Progress"
                        PPD.PlotMsgString(PlotMessageIndex.CancelJobButtonMessage) = "Cancel PDF Creation"
                        PPD.PlotMsgString(PlotMessageIndex.CancelSheetButtonMessage) = "Cancel Sheet PDF Creation"
                        PPD.PlotMsgString(PlotMessageIndex.SheetSetProgressCaption) = "Multi-sheet PDF Create job Progress"
                        PPD.PlotMsgString(PlotMessageIndex.SheetProgressCaption) = "PDF Sheet Creation Progress"
                        Dim oPublisher As Autodesk.AutoCAD.Publishing.Publisher = Autodesk.AutoCAD.ApplicationServices.Application.Publisher
                        DSDDataFile.ReadDsd(DSDFileName)
                        Dim strDWGName As String = CurrAcadDoc.Name
                        Dim obj As Object = Application.GetSystemVariable("DWGTITLED")
                        If System.Convert.ToInt16(obj) = 0 Then
                            strDWGName = "C:\CAD Data\Drawing" & CStr(CInt(Rnd() * 1000)) & ".dwg"
                        Dim PDFPlotConfig As PlotConfig = PlotConfigManager.SetCurrentConfig("DWG To PDF.pc3")
                        CurrAcadDoc.Database.SaveAs(strDWGName, True, DwgVersion.Current, CurrAcadDoc.Database.SecurityParameters)
                        Autodesk.AutoCAD.ApplicationServices.Application.Publisher.PublishDsd(DSDFileName, PPD)
                    End Using
                    'Application.Publisher.PublishExecute(DSDDataFile, PDFPlotConfig)
                End Using
        Catch ex As System.Exception
        End Try
6 REPLIES 6
csludtke
in reply to: csludtke
Added DSD File
Tags (1)
csludtke
After Publish Command
Tags (1)
Balaji_Ram
Here is an example on using the "PublishDsd"
http://adndevblog.typepad.com/autocad/2012/05/how-to-use-the-autodeskautocadpublishingpublisherpubli...
If this does not help with your specific error, can you please provide a buildable sample project and the sample drawings for me to repdroduce the error message ?
Balaji
Developer Technical Services
Autodesk Developer Network
csludtke
in reply to: Balaji_Ram
I have added a simplified solution as an attachment.
I am still unable to get PublishDSD or PublishExecute to work.
I am also having trouble using the API to create a DSD file.
Please note that this is a very simplified example that depicts the behavior
You will have to create a "C:\Temp" folder for this to work
Balaji_Ram
Hi Chris,
Sorry for the delay.
Following minor changes to your project were needed to get it working in AutoCAD 2013 :
1. Commented the call to "CreatePublishEngine".
                'Dim oPlotEngine As Autodesk.AutoCAD.PlottingServices.PlotEngine = Autodesk.AutoCAD.PlottingServices.PlotFactory.CreatePublishEngine
                Dim DSD As New DrawingSheetDatabase(Me)
                Try
                    DSD.WriteDSD()
                    DSD.ExecutePublishProcess()
                    DSD.Dispose()
                End Try
                'If Not oPlotEngine Is Nothing Then
                '    oPlotEngine.Destroy()
                '    oPlotEngine.Dispose()
                '    oPlotEngine = Nothing
                'End If
 2. Included a call to "Readdsd" before using "PublishExecute"
Public Sub ExecutePublishProcess()
        Try
            Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("BACKGROUNDPLOT", 0)
                    PPD.UpperPlotProgressRange = 100
                    PPD.LowerPlotProgressRange = 0
                    PPD.UpperSheetProgressRange = 100
                    PPD.LowerSheetProgressRange = 0
                    oPublisher.PublishExecute(DSDDataFile, PDFPlotConfig)
                End Using
            End Using
            Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("BACKGROUNDPLOT", 1)
        End Try
    End Sub
I have attached the modified sample project.
Balaji
csludtke
Thanks,  I have all of the changes integrated.
Proceeding with cleanup.
”Boost
