.NET
Issues with closeandsave drawings
4 REPLIES 4
e.g.
434 Views, 4 Replies
I have to process a bunch of drawings (Autocad 2014, win7x64), just to open and make sure they are saved in model space. The code I am using is:
[CommandMethod("Test2", CommandFlags.Session)]
        public static void Test2()
            var docs = apps.Application.DocumentManager;
            var lstFiles = new List<string>();
            if (docs.Count > 0)
                apps.DocumentCollectionExtension.CloseAll(docs);
            using (System.Windows.Forms.OpenFileDialog opd = new System.Windows.Forms.OpenFileDialog())
                opd.Title = "Select dwg files:";
                opd.Multiselect = true;
                opd.Filter = "dwg files|*.dwg";
                if (opd.ShowDialog() == System.Windows.Forms.DialogResult.OK)
                    foreach (string s in opd.FileNames)
                        if (!lstFiles.Contains(s))
                            lstFiles.Add(s);
            if (lstFiles.Count != 0)
                foreach (string s in lstFiles)
                    var doc = apps.DocumentCollectionExtension.Open(docs, s, false);
                    using (Database db = doc.Database)
                        using (apps.DocumentLock docLock = doc.LockDocument())
                            using (Transaction tr = db.TransactionManager.StartTransaction())
                                try
                                    apps.Application.SetSystemVariable("TILEMODE", (object)1);
                                catch (System.Exception ex)
                                    apps.Application.ShowAlertDialog(ex.Message);
                                tr.Commit();
                    apps.DocumentExtension.CloseAndSave(doc, s);
But for some reason, it doesn't work; I get the following error:
An exception of type 'System.InvalidOperationException' occurred in mscorlib.dll but was not handled in user code
Additional information: Collection was modified; enumeration operation may not execute.
If there is a handler for this exception, the program may be safely continued.
Any idea why this is happening?
e.g.
4 REPLIES 4
Ajilal.Vijayan
in reply to: e.g.
Tested the code on 2013 & 2014, but didnt brings any error.
jeff
in reply to: e.g.
Remove
closing the document will handle the database associated with it.
You can also find your answers @ TheSwamp
_gile
in reply to: e.g.
Try making the opened document active:
docs.MdiActiveDocument = doc;
The DocumentExtension and DocumentCollectionExtension classes define extension methods which can be called as instance methods:
docs.closeAll(); instead of DocumentCollectionExtension.CloseAll(docs);
docs.Open(s, false); instead of DocumentCollectionExtension.Open(docs, s, false);
doc.CloseAndSave(s); instead of DocumentExtension.CloseAndSave(doc, s);
Gilles Chanteau
GileCAD
GitHub
e.g.
in reply to: _gile
after intensive testing, it seems that it was something wrong with netframework. I used VS2012, I've downgraded to VS2010, uninstall netframework 4.5, reinstall netframework 4, repair Autocad, then upgraded again to VS2012 and since then, no error. I've even disabled one of the videocards (my laptop has two, some kind of battery life saving method which I kind of not trust it anymore.) because one of the error messages was saying something related to "A display driver file (.HDI) is missing or has been corrupted...".
Anyways, since reinstalling the netframework, seems to be ok.
Thanks, one more time to all of you,
e.g.
”Boost
