.NET
Issues running .Net code that uses AcedGetSym in 32-Bit AutoCAD 2015
8 REPLIES 8
Message 1 of 9
ainyoung
796 Views, 8 Replies
I have some .net code that needs to use AcedGetSym.
When the code is ran in AutoCAD 2015 32-bit, i get an error that AcedGetSym cannot be found in acCore.dll.
The same code runs fine in 32 bit verions of 2013 and 2014 and runs fine in 64-bit 2013-2015.
Has anyone else ran into this issue?
Thanks!
8 REPLIES 8
Message 2 of 9
AutoCAD 2015:
x86: "_acedGetSym" or "?acedGetSym@@YAHPB_WPAPAUresbuf@@@Z"
x64: "acedGetSym" or "?acedGetSym@@YAHPEB_WPEAPEAUresbuf@@@Z"
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 9
I'm using p/Invoke to use AcedGetSym.
    'Use P/Invoke for AcedGetSym
    <DllImport("acCore.dll", CharSet:=CharSet.Unicode, _
           CallingConvention:=CallingConvention.Cdecl, EntryPoint:="acedGetSym")> _
    Shared Function acedGetSym(ByVal args As String, <Out()> ByRef result As IntPtr) As Integer
    End Function
Message 4 of 9
For AutoCAD 2015 x86 (32-bit):
           CallingConvention:=CallingConvention.Cdecl, EntryPoint:="_acedGetSym")> _
    End Function
For AutoCAD 2015 x64 (64-bit):
    End Function
Expert Elite Member
Message 5 of 9
ainyoung
in reply to: ainyoung
Here's an example code i wrote where a user can query if an AutoLISP symbol is valid.
I've tested the code in 64 bit versions of AutoCAD 2013 through 2015, and it works fine on those systems.
I've also tested the code on 32 bit versions of AutoCAD 2013 through 2015. It only fails to run on 32 bit 2015.
AGS_Class.vb
'import the AutoCAD/ObjectDBX type libeary
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
Imports System.Text ' for StringBuilder
Imports Autodesk.AutoCAD.DatabaseServices ' For ResultsBuffer
Imports System.Runtime.InteropServices 'for DllImport()
'imports the AutoCAD Type library
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.ApplicationServices
Imports System.Windows.Forms
Public Class AGS_Class
    'Define ThisDrawing. The production code i am working on was converted from VBA to VB.NET, hence this has to be defined.
    Public ReadOnly Property ThisDrawing() As AcadDocument
        Get
            Return DocumentExtension.GetAcadDocument(Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument)
        End Get
    End Property
    'Define the entry point/command.
    <Autodesk.AutoCAD.Runtime.CommandMethod("AIY_AcedGetSym_Test")> _
    Public Sub EntryPoint()
        Dim My_Form1 As New Form1
        My_Form1.ShowDialog()
    End Sub
    End Function
    Public Shared Function AcadGetSym(ByVal varname As String) As ResultBuffer
        ' IntPtr is an integer (used as a pointer for .NET) initialize to zero
        Dim rb As IntPtr = IntPtr.Zero
        ' use the function that was p/Invoked, pass in the name that was
        ' provided by the user and the IntPtr
        Dim stat As Integer = 0
        stat = acedGetSym(varname, rb)
        ' If stat is ok and the IntPtr is not zero create a ResultBuffer and Return it
        If stat = CType(PromptStatus.OK, Integer) AndAlso Not (rb = IntPtr.Zero) Then
            Return CType(DisposableWrapper.Create(GetType(ResultBuffer), rb, True), ResultBuffer)
        ' Getting the symbol failed if we reach this return statement
        Return Nothing
    End Function
    Public Shared Function GetLispStrSym(ByVal sym As String) As String
        ' Get the string value of a Lisp symbol
        ' The name (or expression) of the lisp symbol is passed in sym.
        ' Adapted from CP 214-4 AutoCAD® .NET: Using .NET With Your LISP Applications example
        '   Output values are returned in an AutoCAD specific ResultBuffer.
        '   ResultBuffer can contain int, float, string, etc.
        '   This routine only accomodates a string!
        ' Populate a ResultBuffer with the values of the symbol by calling
        ' local function AcadGetSym which uses acedGetSym that was called through
        ' P/Invoke
        Dim ResBuf As ResultBuffer = AcadGetSym(sym)
        ' Ensure that ResultBuffer is not nothing
        If Not (ResBuf Is Nothing) Then
            Dim s As StringBuilder = New StringBuilder
            ' Append each type and value in the symbol
            For Each val As TypedValue In CType(ResBuf, IEnumerable)
                If val.TypeCode = 5005 Then 'is it a string?
                    s.AppendFormat("{0}", val.Value.ToString)
                Else
                    GetLispStrSym = "Valid LISP symbol, but it's not a string!"
                    Exit Function
            Next
            GetLispStrSym = s.ToString()
        Else
            GetLispStrSym = "*That's not a Lisp Symbol*"
    End Function
End Class
 The simple form code:
Public Class Form1
    'setup an example LISP symbol input.
    Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
        EnterText.Text = "pi"
    End Sub
    'On cliking okay, we pass the entered entered text into GetLispStrSym
    Private Sub Okay_Click(sender As Object, e As EventArgs) Handles Okay.Click
        ReturnTxt.Text = AGS_Class.GetLispStrSym(EnterText.Text).ToString
    End Sub
    'Exit if canceled.
    Private Sub CanIt_Click(sender As Object, e As EventArgs) Handles CanIt.Click
        Me.Close()
    End Sub
End Class
Message 6 of 9
Reread my answer.
Expert Elite Member
Message 7 of 9
I'll give that a try once my 32 bit test VM isn't in use.
Is there any alternative call that works for both 32 bit and 64 bit so i don't have to add a complication constant to do a condiontal compilation?
Right now the same code base is used to build all versions, 2012 to 2015 32 and 64 bit, of a given project.
Message 8 of 9
You can check AutoCAD version and platform (32bit/64-bit) at runtime and call appropriate function. Also you can use conditional compilation.
Expert Elite Member
Message 9 of 9
I finally got a chance to test this out on my 32 bit VM and it works fine!
Thanks for the help!!
”Boost
