.NET
Distinguished Contributor
vince1327
Message 1 of 9 (265 Views)
Issues adding an Attribute to an Entity
265 Views, 8 Replies
05-10-2012 05:46 AM
Hey everyone,
I'm trying to add an attribute to an entity, however it seems that the AttributeDefinition requires a Point3d and as such appear in my modelspace. I don't want this, i just wanted it to appear as an attribute with a value when i click on my entity, is there any way of making it so that i does not add into modelspace?
Cheers
Vince
                    BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead);
                    for (int i = 0; i < prSelectionResult.Value.Count; i++)
                        // Get the entity the user had selected
                        Entity ent = (Entity)trans.GetObject(prSelectionResult.Value[i].ObjectId, OpenMode.ForWrite);
                        if (ent.GetType() == typeof(BlockReference))
                            // Add attribute to layer
                            BlockReference blockRef = (BlockReference)ent;
                            AttributeDefinition attDef = new AttributeDefinition(new Point3d(0d, 0d, 0d), "World, I'm an attribute!", "Hello", "", db.Textstyle);
                            // Add the attribute to to the BlockTrableRecord of the blockdefinition of the selected block
                            ObjectId btrId = blockRef.BlockTableRecord;
                            BlockTableRecord btrBlock = (BlockTableRecord)trans.GetObject(btrId, OpenMode.ForWrite);
                            btrBlock.AppendEntity(attDef);
                            trans.AddNewlyCreatedDBObject(attDef, true);
                            // Add the AttributeReference to the BlockReference
                             AttributeReference attRef = new AttributeReference();
                             attRef.SetAttributeFromBlock(attDef, blockRef.BlockTransform);
                             blockRef.AttributeCollection.AppendAttribute(attRef);
                             trans.AddNewlyCreatedDBObject(attRef, true);
Do I understand correctly that you do not want to attributes were visible on the screen (model space)?
Then it is sufficient to set their property Invisible to true or property Visible to false.
Property Visible is common entity property, but Invisible is only AttributeReference (and AttributeDefinition) property.
attdef.Invisible = true;
attref.Invisible = true;
Moderator
Alexander.Rivilis
Message 2 of 9 (262 Views)
Re: Issues adding an Attribute to an Entity
05-10-2012 06:15 AM in reply to: vince1327
Maybe you can explain in detail what does it do?
It seems to me that this is not the best practice each time to change the number AttributeDefinition in the block.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
vince1327
Message 3 of 9 (253 Views)
05-10-2012 07:03 AM in reply to: Alexander.Rivilis
I was searching through other posts and examples in the forums and came across this. What it does is add an attribute to an entity, in this case:
Hello: World, I'm an Attribute!
As you can see in the attached photo however, the attribute is also placed into modelspace as per the lines:
                            AttributeDefinition attDef = new AttributeDefinition(new Point3d(0d, 0d, 0d), "World, I'm an Attribute!", "Hello", "", db.Textstyle);
What i'm trying to do is avoid having the attribute placed in my modelspace, just in the entity.
Moderator
Alexander.Rivilis
Message 4 of 9 (248 Views)
05-10-2012 07:14 AM in reply to: vince1327
vince1327
Message 5 of 9 (240 Views)
05-10-2012 07:19 AM in reply to: Alexander.Rivilis
Fantastic!!!! That's exactly what i was looking for!!!! Thank you!
***Edited for spelling
Moderator
Alexander.Rivilis
Message 6 of 9 (237 Views)
05-10-2012 07:21 AM in reply to: vince1327
vince1327 wrote:
Fatnastic!!!! That's exactly what i was looking for!!!! Thank you!
:smileyhappy: This is not fantasy - it is a minimal knowledge of the AutoCAD capabilities .
vince1327
Message 7 of 9 (230 Views)
05-10-2012 07:43 AM in reply to: Alexander.Rivilis
I've just begun working with attributes and am very new to the AutoCAD API in general so I was not aware of this property. Although it may seem like minimal knowledge to some, to me it's quite new and something I will definetly remember as I continue :smileyhappy:
Cheers
Vince
Hallex
Message 8 of 9 (225 Views)
05-10-2012 08:06 AM in reply to: vince1327
Would be good as well to add one line in your code
AttributeReference attRef = newAttributeReference();
                        //  additional line:
                            attRef.AdjustAlignment(db);
true);
~'J'~
vince1327
Message 9 of 9 (222 Views)
05-10-2012 08:08 AM in reply to: Hallex
Thanks Hallex, will do!
