Thanks again, i was a little hazy on that...just starting out
mark
"Tony Tanzillo" wrote in message
news:6252408@discussion.autodesk.com...
What you read is about objects within in a database,
not the database itself.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
"mp" wrote in message
news:6252279@discussion.autodesk.com...
Thanks Tony,
re Dispose, I read somewhere you need to call that unless you're in a
transaction in which case the transaction does it automatically...or
something to that effect...is that right?
mark
news:6251699@discussion.autodesk.com...
Right.
Be sure that you call Dispose() on the Database when you're done with it.
news:6251575@discussion.autodesk.com...
Found this snippet which appears to be equivalent to using obj dbx interface
to open dwgs without using editor. just wanted to confirm this is how one
would do (in c#) what one did with GetIntefaceObject(objdbxversion)
Editor ed =
AcAp.Application.DocumentManager.MdiActiveDocument.Editor;
string dwgPath = @"c:\Drawings\tmp.dwg";
Database db = new Database(false,true);
db.ReadDwgFile(dwgPath,
FileOpenMode.OpenForReadAndAllShare, false, string.Empty);
