.NET
Is there any Event to get the Point3D when the mouse is moving using .net
2 REPLIES 2
kevinsir
503 Views, 2 Replies
Is there any Event  or ApI to get the Point3D when the mouse is moving  using .net
I want to get Point3D when the mouse is moving just as CAD shown on  lower left corner. Is there any way to get it with .net?
2 REPLIES 2
Editor.PointMonitor
AutoCAD.NET lesson 6: Input Point Monitor
Facebook | Twitter | LinkedIn
Expert Elite Member
Thanks,I will try it!
”Boost
