.NET
Is there a way to tell if a plot device requires to plot to file?
3 REPLIES 3
396 Views, 3 Replies
Can anybody help me with some advice about how to find out using the .NET API  if a plot device requires a file name when ploting?
E.g. choosing the plot to PDF device would require a file name.
Peter
3 REPLIES 3
SENL1362
                PlotConfig tds = PlotConfigManager.CurrentConfig;
                string plotFile = null;
                if (tds.PlotToFileCapability == PlotToFileCapability.PlotToFileAllowed)
                    tds.IsPlotToFile = true;
                    plotFile = Path.Combine(Path.GetDirectoryName(Application.DocumentManager.MdiActiveDocument.Database.Filename), Path.GetFileNameWithoutExtension(Application.DocumentManager.MdiActiveDocument.Database.Filename));
                    plotFile = plotFile + tds.DefaultFileExtension;
                    if (File.Exists(plotFile))
                        File.Delete(plotFile);
if (tds.IsPlotToFile)
                        plotEngine.BeginDocument(plotInfo, Application.DocumentManager.MdiActiveDocument.Database.Filename, null, 1, true, plotFile);
                    else
                        plotEngine.BeginDocument(plotInfo, Application.DocumentManager.MdiActiveDocument.Database.Filename, null, 1, false, null);
Thanks 100x!
Peter
SENL1362
You're welcome. That's an easy question. Aks for adding custom media then things get interesting Smiley Wink
”Boost
