.NET
Is There a way to edit textformat​ting dialog
3 REPLIES 3
358 Views, 3 Replies
I want to add a custom  button to the textformatting dialog , however, who can tell me how to do!
How  can  I add my custom button behind the OK button?
3 REPLIES 3
arcticad
http://through-the-interface.typepad.com/through_the_interface/2007/05/creating_a_part.html
(defun botsbuildbots() (botsbuildbots))
I am sorry that I know the way to Add custom cui ! However, the problem is  that the above dialog box may not be able to customize。Can you tell me which is node corresponding to the above dialog box?
Alexander.Rivilis
This dialog is not customizable.
Facebook | Twitter | LinkedIn
Expert Elite Member
”Boost
