.NET
.NET
ken.washburn
Message 1 of 12 (424 Views)
Accepted Solution
Is there a way to create a 3D DWF from a drawing using VB.Net
424 Views, 11 Replies
07-13-2012 07:02 AM
Is there a way to create a 3D DWF from a drawing using VB.Net?  I have a program that processes hundreds of drawings and creates a PDF and DWF of each drawing.  I'd like to also create a 3D DWF file, but haven't find anything on it anywhere.  I'm not sure if this would be a Save As, Export or something else.
Ken
I can open your 3d DWF file, but it looks like empty, I can't say why.
1. Try this in the constructor :
            dwfFile = Path.Combine(outputDir, title & "-3d.dwf")
2. Add this at the begining of the Publish() code:
                If File.Exists(dwfFile) Then
                    File.Delete(dwfFile)
                End If
Oopss !...
i removed a DsdData setting I shouldn't: DsdData.DestinationName. This isn't required while DsdData.SheetType = SheetType.SingleDwf (this forces the output file name to be the same as the input dwg).
Here's a VB code which seems to work as you expect:
Imports System.IO
Imports System.Text
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.PlottingServices
Namespace Plottings
Public Class PlotTo3dDwf
Private dwgFile, dwfFile, dsdFile, title, outputDir As String
Public Sub New()
outputDir = DirectCast(Application.GetSystemVariable("DWGPREFIX"), String)
Dim name As String = DirectCast(Application.GetSystemVariable("DWGNAME"), String)
dwgFile = Path.Combine(outputDir, name)
title = Path.GetFileNameWithoutExtension(name)
dwfFile = Path.Combine(outputDir, title & "-3d.dwf") ' <- add the "-3d" suffix to the file name
dsdFile = Path.ChangeExtension(dwfFile, ".dsd")
End Sub
Public Sub New(outputDir As String)
Me.New()
Me.outputDir = outputDir
End Sub
Public Sub Publish()
Dim bgPlot As Short = CShort(Application.GetSystemVariable("BACKGROUNDPLOT"))
Application.SetSystemVariable("BACKGROUNDPLOT", 0)
Try
If Not Directory.Exists(outputDir) Then
Directory.CreateDirectory(outputDir)
Using dsd As New DsdData()
Using dsdEntries As New DsdEntryCollection()
' add the Model layout to the entry collection
Dim dsdEntry As New DsdEntry()
dsdEntry.DwgName = dwgFile
dsdEntry.Layout = "Model"
dsdEntry.Title = title
dsdEntry.Nps = "0"
dsdEntries.Add(dsdEntry)
dsd.SetDsdEntryCollection(dsdEntries)
' set DsdData data
dsd.Dwf3dOptions.PublishWithMaterials = True
dsd.Dwf3dOptions.GroupByXrefHierarchy = True
dsd.SetUnrecognizedData("PwdProtectPublishedDWF", "FALSE")
dsd.SetUnrecognizedData("PromptForPwd", "FALSE")
dsd.SheetType = SheetType.MultiDwf
dsd.NoOfCopies = 1
dsd.ProjectPath = outputDir
dsd.DestinationName = dwfFile
dsd.IsHomogeneous = True
If File.Exists(dsdFile) Then
File.Delete(dsdFile)
' write the DsdData file
dsd.WriteDsd(dsdFile)
' get the Dsd File contents
Dim str As String
Using sr As New StreamReader(dsdFile, Encoding.[Default])
str = sr.ReadToEnd()
End Using
' edit the contents
str = str.Replace("Has3DDWF=0", "Has3DDWF=1")
str = str.Replace("PromptForDwfName=TRUE", "PromptForDwfName=FALSE")
' rewrite the Dsd file
Using sw As New StreamWriter(dsdFile, False, Encoding.[Default])
sw.Write(str)
End Using
' import the Dsd file new contents in the DsdData
dsd.ReadDsd(dsdFile)
Dim pc As PlotConfig = PlotConfigManager.SetCurrentConfig("DWF6 ePlot.pc3")
Application.Publisher.PublishExecute(dsd, pc)
End Using
End Using
Finally
Application.SetSystemVariable("BACKGROUNDPLOT", bgPlot)
End Try
End Sub
End Class
End Namespace
Member
adam
Message 2 of 12 (415 Views)
Re: Is there a way to create a 3D DWF from a drawing using VB.Net
07-13-2012 08:07 AM in reply to: ken.washburn
Hi Ken,
If it appropriate and you are happy using the command line then use "3DDWF"
Adam
ken.washburn
Message 3 of 12 (413 Views)
07-13-2012 08:22 AM in reply to: adam
Adam,
I thought about that, but the SendStringToExecute doesn't run until everything else has finished in vb.net (which doesn't work when batch processing).  And since moving to the 2013 API, I've found that emulating the vba "ThisDrawing.SendCommand" is spotty at best.  Though, I may have to go this route if there is not a direct way to access it.
Ken
*Expert Elite*
_gile
Message 4 of 12 (393 Views)
Re : Is there a way to create a 3D DWF from a drawing using VB.Net
07-14-2012 04:33 PM in reply to: ken.washburn
You can P/Invoke acedCmd which is synchronous.
Here's another way, in pure .NET. Maybe it isn't the best one but it works fine for me.
It creates a DSD file and publish it.
In this example, all layouts are published to DWF and the Model to 3d DWF
using System.IO;
using System.Text;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.PlottingServices;
using Autodesk.AutoCAD.Publishing;
using Autodesk.AutoCAD.Runtime;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace Publish3dDwf
    public class PublishDwf
        // Private fields
        private string dwgFile, dwfFile, dsdFile, tmpFile, title, outputDir;
        private int numOfSections;
        private Database db = HostApplicationServices.WorkingDatabase;
        private Editor ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
        const string FN_PUBLOG = "publish.log";
        // Constructor
        public PublishDwf()
            dwgFile = db.Filename;
            outputDir = Path.GetDirectoryName(dwgFile);
            if (!Directory.Exists(outputDir))
                Directory.CreateDirectory(outputDir);
            title = Path.GetFileNameWithoutExtension(dwgFile);
            dwfFile = Path.ChangeExtension(dwgFile, "dwf");
            dsdFile = Path.ChangeExtension(dwgFile, "dsd");
            tmpFile = Path.Combine(outputDir, "temp.dsd");
            numOfSections = 0;
        // Publishes all layouts, displays a progress bar
        private void Publish()
            try
                Publisher publisher = AcAp.Publisher;
                PlotProgressDialog plotDlg = new PlotProgressDialog(false, numOfSections, true);
                publisher.PublishDsd(dsdFile, plotDlg);
                plotDlg.Destroy();
            catch (System.Exception ex)
                ed.WriteMessage("\nErreur: {0}\n{1}", ex.Message, ex.StackTrace);
        // Creates a DSD file (template)
        private void CreateDSD()
            using (DsdData dsd = new DsdData())
            using (DsdEntryCollection dsdEntCol = CreateDsdEntryCollection())
                numOfSections = dsdEntCol.Count;
                dsd.SetDsdEntryCollection(dsdEntCol);
                dsd.SetUnrecognizedData("PwdProtectPublishedDWF", "FALSE");
                dsd.SetUnrecognizedData("PromptForPwd", "FALSE");
                dsd.SheetType = SheetType.MultiDwf;
                dsd.NoOfCopies = 1;
                dsd.DestinationName = dwfFile;
                dsd.IsHomogeneous = false;
                dsd.LogFilePath = Path.Combine(outputDir, FN_PUBLOG);
                PostProcessDSD(dsd);
        // Creates an entry collection (one per layout) for the DSD file
        private DsdEntryCollection CreateDsdEntryCollection()
            DsdEntryCollection dsdEntCol = new DsdEntryCollection();
            using (Transaction tr = db.TransactionManager.StartTransaction())
                DBDictionary layoutDict = (DBDictionary)tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead);
                foreach (DBDictionaryEntry layoutEntry in layoutDict)
                    Layout layout = (Layout)tr.GetObject(layoutEntry.Value, OpenMode.ForRead);
                    DsdEntry dsdEntry = new DsdEntry();
                    dsdEntry.DwgName = dwgFile;
                    dsdEntry.Layout = layout.LayoutName.ToString();
                    dsdEntry.Title = title + "-" + layout.LayoutName;
                    dsdEntry.Nps = layout.TabOrder.ToString();
                    dsdEntCol.Add(dsdEntry);
            return dsdEntCol;
        // Writes the definitive DSD file from the template and additional infos
        private void PostProcessDSD(DsdData dsd)
            string str, newStr;
            try
                dsd.WriteDsd(tmpFile);
                bool isModel = false;
                using (StreamReader reader = new StreamReader(tmpFile, Encoding.Default))
                using (StreamWriter writer = new StreamWriter(dsdFile, false, Encoding.Default))
                    while (!reader.EndOfStream)
                        str = reader.ReadLine();
                        if (str == "Layout=Model")
                            isModel = true;
                        if (str.Contains("Has3DDWF"))
                            newStr = isModel ? "Has3DDWF=1" : "Has3DDWF=0"; // <- 3dDwf if Model layout
                            isModel = false;
                        else if (str.Contains("OriginalSheetPath"))
                            newStr = "OriginalSheetPath=" + dwgFile;
                        else if (str.Contains("Type"))
                            newStr = "Type=0"; // <- 6 for DwgToPdf
                        else if (str.Contains("OUT"))
                            newStr = "OUT=" + outputDir;
                        else if (str.Contains("IncludeLayer"))
                            newStr = "IncludeLayer=TRUE";
                        else if (str.Contains("PromptForDwfName"))
                            newStr = "PromptForDwfName=FALSE";
                        else if (str.Contains("LogFilePath"))
                            newStr = "LogFilePath=" + Path.Combine(outputDir, FN_PUBLOG);
                        else
                            newStr = str;
                        writer.WriteLine(newStr);
            catch (System.Exception e)
                ed.WriteMessage("\nErreur: {0}\n{1}", e.Message, e.StackTrace);
        // Deletes the DSD files
        private void Cleanup()
            try
                if (File.Exists(dsdFile))
                    File.Delete(dsdFile);
                if (File.Exists(tmpFile))
                    File.Delete(tmpFile);
        // Command
        [CommandMethod("PublishToDwf")]
        public void PublishToDwf()
            short bgp = (short)AcAp.GetSystemVariable("BACKGROUNDPLOT");
            AcAp.SetSystemVariable("BACKGROUNDPLOT", 0);
            CreateDSD();
            Publish();
            Cleanup();
            AcAp.SetSystemVariable("BACKGROUNDPLOT", bgp);
Gilles Chanteau
*Expert Elite*
_gile
Message 5 of 12 (386 Views)
07-15-2012 06:57 AM in reply to: _gile
The upper code is a quick (and dirty) adaptation of the one I used to plot layouts to a PDF file.
Publishing a 3d DWF may be a little more simple (removing unsefull lines).
Here's a little class you can instanciate to call the Publish() method:
Dim plot3d As New PlotTo3dDwf("C:\Temp")
plot3d.Publish()
 C#
using System.IO;
using System.Text;
using Autodesk.AutoCAD.ApplicationServices;
namespace Plottings
    public class PlotTo3dDwf
        private string dwgFile, dwfFile, dsdFile, title, outputDir;
        public PlotTo3dDwf()
            outputDir = (string)Application.GetSystemVariable("DWGPREFIX");
            string name = (string)Application.GetSystemVariable("DWGNAME");
            dwgFile = Path.Combine(outputDir, name);
            title = Path.GetFileNameWithoutExtension(name);
            dsdFile = Path.ChangeExtension(dwfFile, ".dsd");
        public PlotTo3dDwf(string outputDir) : this ()
            this.outputDir = outputDir;
        public void Publish()
            short bgPlot = (short)Application.GetSystemVariable("BACKGROUNDPLOT");
            Application.SetSystemVariable("BACKGROUNDPLOT", 0);
            using (DsdEntryCollection dsdEntries = new DsdEntryCollection())
                // add the Model layout to the entry collection
                dsdEntry.Layout = "Model";
                dsdEntry.Title = title;
                dsdEntry.Nps = "0";
                dsdEntries.Add(dsdEntry);
                dsd.SetDsdEntryCollection(dsdEntries);
                // set DsdData
                dsd.Dwf3dOptions.PublishWithMaterials = true;
                dsd.Dwf3dOptions.GroupByXrefHierarchy = true;
                dsd.SheetType = SheetType.SingleDwf;
                dsd.NoOfCopies = 1;
                dsd.ProjectPath = outputDir;
                dsd.IsHomogeneous = true;
                // write the DsdData file
                dsd.WriteDsd(dsdFile);
                // get the Dsd File contents
                string str;
                using (StreamReader sr = new StreamReader(dsdFile, Encoding.Default))
                    str = sr.ReadToEnd();
                // edit the contents
                str = str.Replace("Has3DDWF=0", "Has3DDWF=1");
                str = str.Replace("PromptForDwfName=TRUE", "PromptForDwfName=FALSE");
                // rewrite the Dsd file
                using (StreamWriter sw = new StreamWriter(dsdFile, false, Encoding.Default))
                    sw.Write(str);
                // import the Dsd file contents in the DsdData
                dsd.ReadDsd(dsdFile);
                PlotConfig pc = PlotConfigManager.SetCurrentConfig("DWF6 ePlot.pc3");
                Application.Publisher.PublishExecute(dsd, pc);
                Application.SetSystemVariable("BACKGROUNDPLOT", bgPlot);
 VB
Imports System.IO
Imports System.Text
Namespace Plottings
        Public Sub New()
        End Sub
            Me.New()
        End Sub
                    dsdEntry.Nps = "0"
                    ' set DsdData data
                    dsd.NoOfCopies = 1
                    Dim str As String
                    End Using
                    ' edit the contents
                        sw.Write(str)
                    End Using
                End Using
            End Using
        End Sub
    End Class
End Namespace
Gilles Chanteau
ken.washburn
Message 6 of 12 (365 Views)
07-16-2012 06:54 AM in reply to: _gile
_gile, thanks for the code!  I will try this when I get time later this week.
Ken
ken.washburn
Message 7 of 12 (357 Views)
07-16-2012 09:56 AM in reply to: ken.washburn
_gile, I got a chance to try your second set of code this morning, and it appears to work, as far as creating a dwf file.  However, the dwf file it creates I can't open (see attached) - it hangs up after starting to open.  I'm using Map 3D 2013.  Note that I can create 3DDWF from the command line (so I know that the drivers are there and working - unless this uses something different).
Also, I'm not familiar with working with DSD files and have the following questions:
1. I want the 3D DWF file to have a different name than the drawing (as I will already have a 2D DWF file in the folder) - somthing like Drawingname-3D.dwf.  So where would I change that?  I tried changing the "name" variable and the "dwfFile" variable, but neither worked (i.e. it didn't create the file).
2. Since the folder that I'm creating the new 3D DWF file in may already have an existing (older) 3D DWF, I want to overwrite the older file.  While I can write something to check for the file and delete it, I was wondering if there was something in your Publish() code section that could force an overwrite and supress any dialog boxes (that ask you if you want to overwrite the file).
Thanks again for your help on this.
Ken
*Expert Elite*
_gile
Message 8 of 12 (354 Views)
07-16-2012 12:29 PM in reply to: ken.washburn
                End If
Gilles Chanteau
ken.washburn
Message 9 of 12 (342 Views)
07-16-2012 02:36 PM in reply to: ken.washburn
_gile, thanks for the suggestions.  I just tried Publish within Autocad and I get the same results (i.e. the dwf is blank).  However, 3DDWF does work.  I think I had the problem with both Publish and 3DDWF not working when I first installed Map 3D 2013 and got 3DDWF working after re-installing.  I will try a reinstall to see if I can get that piece working.
Otherwise, I think your code works fine.
Thanks again for your help!
Ken
ken.washburn
Message 10 of 12 (332 Views)
07-17-2012 07:56 AM in reply to: ken.washburn
_gile, one more question.  I have everything working (the reinstall worked on the Publish command), except the naming (i.e. to drawingname-3D.dwf).  I don't see where in the Publish sub where it actually uses the dwfFile variable.  I see that it uses the dwgFile variable, but not the dwfFile variable.
Ken
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
