.NET
Is Possible to roll back variable within undo command , outside of transaction?
6 REPLIES 6
JanetDavidson
554 Views, 6 Replies
I need to be able to roll back my variables if user apply an UNDO. I am just wondering if this is possible and what is your trick in this regard. Let's say.
Myinteger =1
Startstransaction
trans commint
Myinteger=2
Startstransaction
trans commint
Myinteger=3
if user does undo 2 times  the Variable  Myinteger  keep the value  3 . I want it back to 1. How?
Thanks for any help or workaround or trick.
Janet.
6 REPLIES 6
my understanding is one undo makes one (main) transaction-part undone. With main-transaction I mean the "master" transaction without looking to any nested transactions.
If you want to undo more than one actions with one step you can set undo-markers.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Hello Alfred,
Thanks for your time looking into my question.
My concern is  the public shared variable in whole project  ( in this simple sample, say , "myinteger".
When I  undo a  command that variable doesn't roll back ot initial value .
Hope I explained or you need a asimple example code?
Janet.
Ok, you want your local variable to be restored, sorry, I did'nt check that.
So my ideas would be then: either check CommandEnded-event (watchign for command _UNDO) and use a stack for every variable-change or use a drawings-sysvar for saving and restoring your variable, because the sysvars (e.g. USERI1) will notice undo-commands.
In this case (I normally don't use the USER-vars) the advantage is also that you have saved it with the drawing. Because if the user changes the drawing between step 2 and step 3 your global variable will also have to be reset as the other drawing may stay at another step.
- alfred -
Alfred NESWADBA
Thanks Alfred ,  I got it and I understood.
Now let's say that local vairable  instead of one,  is 500 local variables .
In this case what would be the solution ?
Janet.
store it in
  • Dictionary
  • ExtendedEntityData
  • Block with 500 Attributes
Just a few examples 😉
- alfred -
Alfred NESWADBA
Hi alfred, I like Attributes Idea, Yeah that will do the job for me.
Thanks for showing the trick.
”Boost
