Is it safe to use Database in the Initialize() method?
When I do it, then my code looks something like this:
public void Initialize() {
  Document doc = cad.DocumentManager.MdiActiveDocument;
  if (null == doc)
    return;
  Database db = doc.Database;
  Editor ed = doc.Editor;
  using (doc.LockDocument()) {
    using (Transaction tr = db.TransactionManager.StartTransaction()) {
      ed.WriteMessage("\nThe \"{0}\" assembly successfully loaded.\n",
        this.GetType().Assembly.Location);
      // TODO: Here is my code of working with Database...
      tr.Commit();
Assembly can be registered for autoloading (through the registry record or BUNDLE engine). I hadn't problems with such approach, but I remember - Alexander Rivilis wrote he had. He wrote what the Document (or Database) can be initialized not completely at the time of operation of this code. Ok, how can I check initialization of these objects was finished?
max.senft
it seems this matches your "problem": http://through-the-interface.typepad.com/through_the_interface/2013/01/displaying-a-dialog-on-autoca... Smiley Indifferent
At least in the introduction Kean wrote the sentence: "[...]he needed to display a dialog on AutoCAD startup, but found that it was too soon to do so on IExtentionApplication.Initialize()[...]".
Regards
Max
