.NET
Is it possible to edit/change code while debugging?
2 REPLIES 2
diegoal
597 Views, 2 Replies
Hello guys,
I am moving from VBA to VS2010/12 and I am having my first problem 🙂
Firstly, I read that I should install AutoCad 2013 DoNet Wizard to be able to compile and debug my code. After install it I managed to "debug" when I set the brakepoint but I couldn't change the code while debugging...
I did a fast search in this forum and I found some similar issues but they where old posts (before C3D2012 and VS2012). So, is it possible now to edit code while debugging as I was able to do in VBA? This will save me a lot of time. Mostly in my case once I'll make a lot of beginner mistakes...
In some post I found that we should install a virtual machine and run in 32bits mode to be able to edit. This is the best solution?
Thank you very much,
Diego Álvares
Civil Engineer @ Trento Engenharia Ltda.
www.trentoengenharia.com.br
Autocad Civil 3D 2010 to 2017 - Infrastructure Design Suite
Windows 7 64 i7 4770 @3.40GHz 8GB Ram GeForce GTX 760
Please use the Accept as Solution or Kudo buttons when appropriate
2 REPLIES 2
arcticad
in reply to: diegoal
The short answer is you can not edit the code while running in 64 bits.
There has been some discussion about reloading dll files without restarting.
http://forums.autodesk.com/t5/NET/NET-RELOAD-Utility-for-Visual-Studio-Download-Here/m-p/3185104/hig...
(defun botsbuildbots() (botsbuildbots))
diegoal
in reply to: arcticad
Thanks Arcticad.
I read that I should test and debug code using Virtual Machine with W7 32 Bits. Would I have problems after it, once my code will be ok, to upgrade and compile my code to 64 Bits?
Thanks again.
Diego Álvares
”Boost
