.NET
Is it possible to determine if a non-active drawing is new?
6 REPLIES 6
495 Views, 6 Replies
After doing a bit of searching on this forum, I learned that you can use the DWGTITLED system variable to determine if a drawing is new or has been previously saved. My current understanding is that you can only use this system variable to check whether the current active document is new or not.
Is it possible to check if a non-active document is new?
6 REPLIES 6
I haven't tried this, so can't say if it will work, or not:
Try setting the HostApplicationServices.WorkingDatabase to the database of the
document you want to check, then get the value of DWGTITLED, and finally, make
sure to restore the previous value of WorkingDatabase to what it was before you
changed it.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2011
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6399782@discussion.autodesk.com...
Tony,
Thanks for the response. I gave this a shot, but unfortunately it still seemed to retain the value of the DWGTITLED variable based on the active document. Below is the sample code I used. For my test, I had 2 documents open in AutoCAD: 1 new and 1 previously saved.
{code}
// get the first inactive document found in the collection
var docs = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Cast();
var doc = docs.FirstOrDefault(d => !d.IsActive);
var originalDb = HostApplicationServices.WorkingDatabase;
var dwgTitledOrig = Application.GetSystemVariable("DWGTITLED");
MessageBox.Show("Original DWGTITLED = " + dwgTitledOrig);
HostApplicationServices.WorkingDatabase = doc.Database;
var dwgTitledChanged = Application.GetSystemVariable("DWGTITLED");
MessageBox.Show("DWGTITLED after changing working DB = " + dwgTitledChanged);
HostApplicationServices.WorkingDatabase = originalDb;
var dwgTitledRestored = Application.GetSystemVariable("DWGTITLED");
MessageBox.Show("DWGTITLED after restoring original DB = " + dwgTitledRestored);
{code}
One thing I noticed is that for a new document, the Document.Name and Database.Filename properties are different. Would it be possible to determine if a document is "new" based on these two properties not being equal or are there other situations where this could also be the case?
Changing 'Active' documents from within a command, the command should have a Session commandflag set...
[CommandMethod("dwgCheck",CommandFlags.Session)]
Also, setting the HostApplicationServices workingdatabase does not make the document Active, that is done with MDIActiveDocument...
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument = doc;
-james
I think you might have not understood the OP's problem.
He's trying to determine the status of a non-active document
without making it the active document.
wrote in message news:6400692@discussion.autodesk.com...
= doc;
-james
I was afraid of that.
You can't reliably use the fact that the database filename
and the document Name properties are not the same, because
that might be the case if you are editing a template file.
You can P/Invoke this API that's exported from acad.exe:
bool acedIsNamedDrawing( AcApDocument* pDoc )
wrote in message news:6400638@discussion.autodesk.com...
Tony,
{code}
var docs =
{code}
Thanks Tony! It's good to know that there is at least a way to solve the problem.
”Boost
