.NET
Is it possible to change the saved xref path without reattaching the xref
1 REPLY 1
RamanSBV
654 Views, 1 Reply
Please guide me
Raman
1 REPLY 1
BrentBurgess1980
in reply to: RamanSBV
Try this - I haven' tested it yet though.
public static void Repath(Database db, string xrefName, string newPath)
            if (string.IsNullOrEmpty(newPath))
                throw new Autodesk.AutoCAD.Runtime.Exception(ErrorStatus.FileNotFound, "The path can not be found");
            if (!File.Exists(newPath))
                throw new Autodesk.AutoCAD.Runtime.Exception(ErrorStatus.FileNotFound, "The file can not be found");
            BlockTableRecord btr = default(BlockTableRecord);
            using (Transaction tr = db.TransactionManager.StartTransaction())
                XrefGraph DbXrGraph = db.GetHostDwgXrefGraph(true);
                XrefGraphNode XrGraphNode = null;
                XrGraphNode = DbXrGraph.GetXrefNode(xrefName);
                btr = (BlockTableRecord)tr.GetObject(XrGraphNode.BlockTableRecordId, OpenMode.ForWrite);
                btr.PathName = newPath;
                tr.Commit();
”Boost
