.NET
.NET
andy_pu
Message 1 of 3 (197 Views)
is it possible to call the command "flatshot" without dialogue
197 Views, 2 Replies
01-22-2014 12:05 AM
Hi! Can I call flatshot with default parameters from command line оr .NET API? Without showing dialog
Board Manager
StephenPreston
Message 2 of 3 (156 Views)
Re: is it possible to call the command "flatshot" without dialogue
01-24-2014 12:19 PM in reply to: andy_pu
Hi Andy,
the FLATSHOT command doesn't have a command line version (there is no -FLATSHOT variant of the command) and it still shows its dialog when the CMDDIA sysvar is set to 0. Therefore, i'm going to say that its not possible to silently invoke this command from the API. You could use Windows messages to send data to the dialog, but that is cumbersome at best. The only other option I see is to implement your own flattening routine that mimics FLATSHOT, but that is a lot of work.
Cheers,
Stephen Preston
Autodesk Developer Network
andy_pu
Message 3 of 3 (135 Views)
01-25-2014 10:46 AM in reply to: StephenPreston
Thank you so much for explanation!!!
