.NET
is DBObjectCollection bug ?
10 REPLIES 10
Message 1 of 11
sieben
570 Views, 10 Replies
DBObjectCollection objColl = curve.GetSplitCurves(dColl);
//OK two entitys will be drawed ::type 1
if (objColl.Count == 3)
ent = (Entity)objColl[0];
DrawEntity(ent);
ent = (Entity)objColl[1];
ent = (Entity)objColl[2];
DrawEntity(ent);
//OK three entitys will be drawed ::type 2
DrawEntity(ent);
DrawEntity(ent);
DrawEntity(ent);
//Error: can not access objColl[2] ::type 3
DrawEntity(ent);
DrawEntity(ent);
is DBObjectCollection bug or other reason ?
10 REPLIES 10
Message 2 of 11
in reply to: sieben
Is that the error? If not, what is the error?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5607043@discussion.autodesk.com...
DrawEntity(ent);
DrawEntity(ent);
DrawEntity(ent);
DrawEntity(ent);
DrawEntity(ent);
DrawEntity(ent);
DrawEntity(ent);
Message 3 of 11
sieben
in reply to: sieben
// thanks Tony Tanzillo !!!
// the total caode as follow
[CommandMethod("SSG")]
public void GeometryTrans()
//**************begin here
Line line1 = new Line(new Point3d(0, 0, 0), new Point3d(100, 0, 0));
adb.DrawLine(line1); //Transaction commit entity to WorkingDatabase
using (Transaction ctrans = mmc.db.TransactionManager.StartTransaction())
Line line2 = (Line)ctrans.GetObject(line1.ObjectId, OpenMode.ForWrite);
BreakCurve(line2, new Point3d(20, 0, 0), new Point3d(50, 0, 0));
ctrans.Commit();
public bool BreakCurve(Curve curve, Point3d p1, Point3d p2)
try
Point3d p11 = curve.GetClosestPointTo(p1, false);
double param1 = curve.GetParameterAtPoint(p11);
Point3d p21 = curve.GetClosestPointTo(p2, false);
double param2 = curve.GetParameterAtPoint(p21);
DoubleCollection dColl = new DoubleCollection(2);
if (param1 < param2)
dColl.Add(param1);
dColl.Add(param2);
else
dColl.Add(param2);
dColl.Add(param1);
Entity ent;
if (objColl.Count == 2)
adb.DrawEntity(ent);
else if (objColl.Count == 3)
//ent = (Entity)objColl[1]; // if not note this line code ,all will be OK,
//adb.DrawEntity(ent);
ent = (Entity)objColl[2]; //here catch System.Exception ex
//ex.Message = Insertion index was out of range. Must be non-negative and
//less than or equal to size.Parameter name: index
curve.Erase();
return true;
catch (Autodesk.AutoCAD.Runtime.Exception ex)
smc.WriteLine("BreakCurve Failure : " + ex.Message, 0);
return false;
catch (System.Exception ex)
return false;
Message 4 of 11
in reply to: sieben
That does appear to be a bug.
Try doing this just before using the default indexer:
foreach(DBObject obj in objColl)
if( obj == null )
throw new InvalidOperationException();
The above will force the creation of wrappers for
the entire collection (DBObjectCollection doesn't
create wrappers for native objects until they are
actually requested).
wrote in message news:5608096@discussion.autodesk.com...
ctrans.Commit();
try
dColl.Add(param1);
dColl.Add(param2);
else
dColl.Add(param2);
dColl.Add(param1);
Entity ent;
curve.Erase();
return true;
return false;
return false;
Message 5 of 11
in reply to: sieben
That does look like a bug.
Try doing this before using the default indexer:
if( obj == null )
ctrans.Commit();
try
dColl.Add(param1);
dColl.Add(param2);
else
dColl.Add(param2);
dColl.Add(param1);
Entity ent;
curve.Erase();
return true;
return false;
return false;
Message 6 of 11
sieben
in reply to: sieben
Tony Tanzillo : thank you very much!
you code can prevent the exception.
I think what it do is to visit the DBObjectCollection
form index of 0,must in turn,when visit the index,do something
as initialize the member of DBObjectCollection or complete
DBObjectCollection stack.something like my code ,before visit
index must visit index[i-1].
Message 7 of 11
in reply to: sieben
Hi Sieben
Sorry for off-topic
Can you share the local functions:
GetSplitCurves and DrawEntity here
That's very interesting for me
~'J'~
Message 8 of 11
in reply to: sieben
GetSplitCurves() is a method of the Curve class.
wrote in message news:5608528@discussion.autodesk.com...
Hi Sieben
Sorry for off-topic
~'J'~
Message 9 of 11
in reply to: sieben
Aha! Thanks again
~'J'~
Message 10 of 11
sieben
in reply to: sieben
Hi Fatty! DrawEntity funtion code as follow,
GetSplitCurves() as Tony Tanzillo say.
public static ObjectId DrawEntity(Entity ent)
try
Database db = HostApplicationServices.WorkingDatabase;
using (Transaction trans = db.TransactionManager.StartTransaction())
BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead);
BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
btr.AppendEntity(ent);
trans.AddNewlyCreatedDBObject(ent, true);
trans.Commit();
return ent.ObjectId;
catch
return ObjectId.Null;
Message 11 of 11
in reply to: sieben
Thanks a lot
Cheers 🙂
~'J'~
”Boost
