.NET
Invisible viewport
3 REPLIES 3
harryliu3140
1041 Views, 3 Replies
Invisible viewport
Hi, Experts of ObjectARX
I have a function to find all the viewports on a layout and fill the viewport list. But the routine finds viewport which is not exist in the layout. The invisible viewport seems can’t be deleted or the drawing file can’t be open properly. Maybe they are fundamental of those visible viewport. How can I detect this character? The function is listed behind.
Thanks to all attention.
Harry
    Public Function FindViewport(mylay As Layout, btr As BlockTableRecord, ByRef vplist As List(Of Viewport)) As Viewport
        Dim id As ObjectId
        Dim basepoint As Point3d = New Point3d(0, 0, 0)
        Dim insertpoint As Point3d = New Point3d(0, 0, 0)
        Dim uprt, btlt As Point3d
        Dim viewuprt, viewbtlt As Point3d
        Dim layid As ObjectId = btr.OwnerId
        Dim viewidcollection As ObjectIdCollection
        vplist.Clear()
        viewidcollection = mylay.GetViewports
        uprt = mylay.Extents.MaxPoint
        btlt = mylay.Extents.MinPoint
        FindViewport = Nothing
        For Each id In viewidcollection
            FindViewport = id.GetObject(Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite, True)
            viewuprt = FindViewport.CenterPoint.Add(New Vector3d(FindViewport.Width / 2, FindViewport.Height / 2, 0))
            viewbtlt = FindViewport.CenterPoint.Add(New Vector3d(-FindViewport.Width / 2, -FindViewport.Height / 2, 0))
            vplist.Add(FindViewport)
        Next
    End Function
3 REPLIES 3
arcticad
in reply to: harryliu3140
did you check if the obj.iserased ?
(defun botsbuildbots() (botsbuildbots))
jeff
Your probably mean the paperspace viewport.
Each paperspace layout has viewport and you maybe think of it as the one that shows the paper background and you add "floating" viewports which give a view to modelspace.
If you look at description of Layout.GetViewports in docs
This function returns a collection of ObjectIds of all the Viewports that exist in the Layout's paperspace. The first ID in the list will be the paperspace viewport. If the list returned is empty, then this Layout has never been switched to (activated). The list is updated each time a layout is activated, and kept up-to-date while that layout is active (whenever viewports are added or deleted).
There is also Database.GetViewports which takes a boolean argument
Input flag indicating whether to return paperspace viewports associated with layouts
You can also find your answers @ TheSwamp
harryliu3140
I just got a chance to try Jeff's suggestion. It's works all right now.
Thank you, Jeff
”Boost
