.NET
Invalid Object Array exception while calling CopyObjects
3 REPLIES 3
935 Views, 3 Replies
I am getting Invalid Object array error on following line:
oSourceFile.CopyObjects(objCollection, m_oActiveDoc.Blocks);
Code is given below
http://pastie.org/8304282
Tags (1)
3 REPLIES 3
Balaji_Ram
Here is a sample code that worked ok.
        If oAcadApp IsNot Nothing Then
            Dim oActiveDoc As AcadDocument
            oActiveDoc = oAcadApp.ActiveDocument
            Dim oSourceDoc As AcadDocument
            oSourceDoc = Nothing
            For Each oDoc As AcadDocument In oAcadApp.Documents
                If ("C:\Temp\Test.dwg").ToUpper() = oDoc.FullName.ToUpper() Then
                    oSourceDoc = oDoc
                    Exit For
                End If
            Next
            If oSourceDoc IsNot Nothing Then
                ' Get the block to copy
                Dim myBlock As AcadBlock
                myBlock = oSourceDoc.Blocks.Item("Test")
                ' Gather the entities in the block to copy
                Dim objects(0 To myBlock.Count - 1) As AcadEntity
                Dim i As Integer
                i = 0
                For Each obj In myBlock
                    objects(i) = obj
                    i = i + 1
                Next obj
                ' Copy the block from the source to the active drawing
                ' Add a new block
                Dim newBlock As AcadBlock
                newBlock = oActiveDoc.Blocks.Add(myBlock.Origin, myBlock.Name)
                ' Copy the objects to the new block
                oSourceDoc.CopyObjects(objects, newBlock)
            End If
        End If
Please note that the collection of objects to the "CopyObjects" method is a collection of AcadEntity.
Balaji
Developer Technical Services
Autodesk Developer Network
in reply to: Balaji_Ram
You already binding it early. This is nto what I am looking for. The objective was to use both parameters of CopyObject as Late Binding.
And all this is required to detect INstalled AutoCad copy on Machine because I don't want to compile code for different versions of AutoCAD.
How can I make a single piece of code working for all versions of AutoCAD?
Balaji_Ram
Sorry, I do not find any way to do that.
The "CopyObjects" method does not work with an Object array.
Balaji
”Boost
