I am getting Invalid Object array error on following line:
oSourceFile.CopyObjects(objCollection, m_oActiveDoc.Blocks);
Code is given below
Here is a sample code that worked ok.
If oAcadApp IsNot Nothing Then Dim oActiveDoc As AcadDocument oActiveDoc = oAcadApp.ActiveDocument Dim oSourceDoc As AcadDocument oSourceDoc = Nothing For Each oDoc As AcadDocument In oAcadApp.Documents If ("C:\Temp\Test.dwg").ToUpper() = oDoc.FullName.ToUpper() Then oSourceDoc = oDoc Exit For End If Next If oSourceDoc IsNot Nothing Then ' Get the block to copy Dim myBlock As AcadBlock myBlock = oSourceDoc.Blocks.Item("Test") ' Gather the entities in the block to copy Dim objects(0 To myBlock.Count - 1) As AcadEntity Dim i As Integer i = 0 For Each obj In myBlock objects(i) = obj i = i + 1 Next obj ' Copy the block from the source to the active drawing ' Add a new block Dim newBlock As AcadBlock newBlock = oActiveDoc.Blocks.Add(myBlock.Origin, myBlock.Name) ' Copy the objects to the new block oSourceDoc.CopyObjects(objects, newBlock) End If End If
Please note that the collection of objects to the "CopyObjects" method is a collection of AcadEntity.
You already binding it early. This is nto what I am looking for. The objective was to use both parameters of CopyObject as Late Binding.
And all this is required to detect INstalled AutoCad copy on Machine because I don't want to compile code for different versions of AutoCAD.
How can I make a single piece of code working for all versions of AutoCAD?
Sorry, I do not find any way to do that.
The "CopyObjects" method does not work with an Object array.
