.NET
Introducing AutoCAD DevBlog
4 REPLIES 4
StephenPreston
3793 Views, 4 Replies
Thought some of you might like to bookmark this - http://adndevblog.typepad.com/autocad.
Cheers,
Stephen Preston
Autodesk Developer Network
4 REPLIES 4
SENL1362
in reply to: StephenPreston
Nice work.
Easy to understand dynamic and linq samples from Philippe Leefsma.
using these new c# items programming is almost similar to VBA using variants especially for selections.
Realy impressive.
fieldguy
Nivce work - than you!
Is there any way to submit requests?  I am working on Map queries and propertyalteration and I could use a push or shove in the right direction.  I can't find any examples on how to use it.
StephenPreston
in reply to: fieldguy
As its a Map question, have you tried asking on the Map 3D Developer forum? - http://forums.autodesk.com/t5/AutoCAD-Map-3D-Developer/bd-p/84.
Cheers,
Stephen Preston
khoa.ho
Excellent work! I found this blog is very useful. Thank you.
Khoa
”Boost
