.NET
IntersectWith issue (possible bug)
6 REPLIES 6
ahmed.felix
542 Views, 6 Replies
IntersectWith() is only working with the first segment of a polyline. Anybody knows why is this?
Reproducing the problem: draw a circle, then draw a polyline over it (both of them manually in AutoCAD) and get the intersections (programatically). If it's a multiple segment polyline it will only return the intersections where the circle crossed the first segment regardles of how many intersections with the polyline really exist.
6 REPLIES 6
in reply to: ahmed.felix
It works for me using 07. What version are you using - post your code.
wrote in message news:5483877@discussion.autodesk.com...
ahmed.felix
Dim objDrawingSpace As New DrawingSpace.DrawingSpace
Dim entObject1 As Entity
Dim entObject2 As Entity
Dim acadDB As Database = HostApplicationServices.WorkingDatabase
Dim acadTrans As Transaction = acadDB.TransactionManager.StartTransaction
entObject1 = objDrawingSpace.GetEntity("Select Object 1", acadTrans)
entObject2 = objDrawingSpace.GetEntity("Select Object 2", acadTrans)
Dim colIntersection As New Point3dCollection
entObject1.IntersectWith(entObject2 , Intersect.OnBothOperands, colIntersection, 1, 1)
MsgBox(colIntersection.Count)
objDrawingSpace.GetEntity is a function that just prompts a message to the command line and returns the object selected by the user. I've tried different scenarios, like a drawing a line and then drawing a polyline zigzagging over it, still returns only 1 intersection even though there were really 10. I'm using Autocad 2006 and Visual Studio 2005
Use 0, 0 instead of 1, 1 for your graphics markers. 0 is the default - none
used.
wrote in message news:5490211@discussion.autodesk.com...
ahmed.felix
Thanks! It works now. The problem was exactly that, I didn't know what the graphics markers meant or were for, and since everything else seemed to be working fine I assumed 1,1 was ok.
pellacad
Paul and Ahmed,
Why would this line of code...
Dim colIntersection As New Autodesk.AutoCAD.Geometry.Point3dCollection
...generate this error...
"The specified module could not be found."
I am supremely stuck.
pellacad
Why would this code not be recognized in my program (when I try to copy and use the above sub.)
"Dim objDrawingSpace As New DrawingSpace.DrawingSpace"
”Boost
