.NET
.NET
Valued Contributor
3 Kudos
Post 1 of 10
IntersectWith gives MissingMethodException
286 Views, 9 Replies
06-11-2012 08:47 PM
Hi, I am using "IntersectWith" method as following...
   foreach (ObjectId id in col_FillingArea)
                                Entity ent_FillingArea = tr.GetObject(id, OpenMode.ForRead) as Entity;
                                if (ent_FillingArea != null)
                                    foreach (ObjectId id_Terrain in col_TerrainLine1)
                                        Entity ent_TerrainLine = tr.GetObject(id_Terrain, OpenMode.ForRead) as Entity;
                                        Point3dCollection pntCol = new Point3dCollection();
                                        try
                                            ent_FillingArea.IntersectWith(ent_TerrainLine, Intersect.OnBothOperands, pntCol,
new IntPtr(0), new IntPtr(0));
                                        catch (Autodesk.AutoCAD.Runtime.Exception e)
                                            doc.Editor.WriteMessage("\n"+e.Message+"\n");
                                        foreach (Point3d pnt in pntCol)
                                            BlockTable blkTbl = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                                            BlockTableRecord blkTblRec = tr.GetObject(blkTbl[BlockTableRecord.ModelSpace],OpenMode.ForWrite) as BlockTableRecord;
                                            DBPoint dbPnt = new DBPoint(pnt);
                                            blkTblRec.AppendEntity(dbPnt);
                                            tr.AddNewlyCreatedDBObject(dbPnt, true);
But I keep getting "MissingMethodException"
Any idea?
I am using ObjectARX 2011, AutoCAD 2010 Civil 3D, and VS 2010.
Thank you.
"binary compatible" means binary BACKWARD compatible (it is hardly one can say an application is FOREWARD compatible). That means, an app compiled with older version of components/libraries will work in a computer where only newer version of the components/libraries avaline, if he components/libraries are backwork compatible. However, if the app is compiled with new version of components/libraries and run in computer where only older components/libraries available, the app may or may not work (most likely not). No software vender would gurantee its software to be FOREWARD compatible, so that their hands are tied to improve/enhance there product, even they do not break existing functionalities (BACKWARD compatibility).
"Binary Compatible" here only means that the newer version did not break existing functionalities.
So, reference a later version of library and develop against loder version is a bad practice in general, even it may work in particylar cases.
1,219 Kudos
Post 2 of 10
Re: IntersectWith gives MissingMethodException
06-12-2012 01:06 AM in reply to: dynamicscope
what type of entity is your ent_FillingArea?
What happens if you try this
Dim tCurve as DatabaseService.Curve = TryCast(ent_FillingArea,DatabaseServices.Curve)
...does this result in a valid object in tCurve or is it then nothing?
- alfred -
Alfred NESWADBA
Valued Contributor
3 Kudos
Post 3 of 10
06-12-2012 02:34 AM in reply to: Alfred.NESWADBA
The entity are Polylines.
And I tried to cast it as Polyline.
No compile error.
1,219 Kudos
Post 4 of 10
06-12-2012 02:38 AM in reply to: dynamicscope
>> No compile error.
Does that mean the code could be compiled but the error raises at runtime?
IMHO you have the wrong references set then.
What details does the exception have for you if you use Try...Catch...End Try?
- alfred -
Alfred NESWADBA
Distinguished Mentor
91 Kudos
Post 5 of 10
06-12-2012 07:26 AM in reply to: dynamicscope
"I am using ObjectARX 2011, AutoCAD 2010 Civil 3D, and VS 2010." : Why are you referencing ObjectARX2011 in a 2010 project?
Gaston Nunez
Valued Contributor
3 Kudos
Post 6 of 10
06-25-2012 01:37 AM in reply to: gasty1001
Well, I couldn't find ObjectARX 2010 on the download website.
Plus, I asked Autodesk Tech support about version compatibility, and they answered that AutoCAD 2010, 2011, 2012 are binary compatible. Hence ARX 2011 could work with CAD 2010.
Do you still think this could be compatibility issue?
Jake
Valued Contributor
3 Kudos
Post 7 of 10
06-25-2012 01:39 AM in reply to: Alfred.NESWADBA
Well the code doesn't properly catch the exception.
I think the AutoCAD catches the MessingMethodException even before it goes into my catch block.
Weird...
Jake
217 Kudos
Post 8 of 10
06-25-2012 06:47 AM in reply to: dynamicscope
91 Kudos
Post 9 of 10
06-25-2012 07:25 AM in reply to: dynamicscope
You can download ObjectArx 2010 from here: http://forums.autodesk.com/t5/Autodesk-ObjectARX/objectARX-for-autocad-2010/td-p/3423625
Gaston Nunez
Valued Contributor
3 Kudos
Post 10 of 10
06-26-2012 07:27 PM in reply to: gasty1001
Awesome.
Now, I will try with ObjectARX 2010.
Thank you all for your support.
