.NET
Distinguished Contributor
7 Kudos
Post 1 of 7
Accepted Solution
IntersectWith bug
387 Views, 6 Replies
01-20-2014 12:20 AM
A little quiz: how many intersections between this xline and this polyline?
AutoCAD answer: 3
Test code:
[CommandMethod("TESTINTERSECTWITH")]
public void TestIntersectWith()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    var peo = new PromptEntityOptions("\nSelect the Xline: ");
    peo.SetRejectMessage("\nThis entity is not an Xline.");
    peo.AddAllowedClass(typeof(Xline), true);
    PromptEntityResult per = ed.GetEntity(peo);
    if (PromptStatus.Cancel == per.Status) return;
    ObjectId xlineId = per.ObjectId;
    peo.Message = "\nSelect the polyline: ";
    peo.SetRejectMessage("\nThis entity is not a polyline.");
    peo.AddAllowedClass(typeof(Polyline), true);
    ObjectId plineId = per.ObjectId;
    using (Transaction tr = db.TransactionManager.StartTransaction())
        var xline = (Xline) tr.GetObject(xlineId, OpenMode.ForRead);
        var pline = (Polyline)tr.GetObject(plineId, OpenMode.ForRead);
        var intersections = new Point3dCollection();
        xline.IntersectWith(pline, Intersect.OnBothOperands, intersections, IntPtr.Zero, IntPtr.Zero);
        var currentSpace = (BlockTableRecord) tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
        foreach (Point3d intersection in intersections)
            var p = new DBPoint(intersection);
            currentSpace.AppendEntity(p);
            tr.AddNewlyCreatedDBObject(p, true);
        tr.Commit();
IntersectWith finds two points at the north intersection (tested on AutoCAD 2013 & 2014).
sorry to say, but I searched all the time now for a thread where I mentioned that, it's some years ago and exactly what you found out ... the extension of a segment is another intersection point (and this didn't start with 2013, it was the same issue releases earlier too).
You can now (time consuming, I know) verify each intersection point if it's on the curve or not (distance between returned intersection point and the Curve.GetClosestPointTo(xxx)).
- alfred -
*Expert Elite*
1,216 Kudos
Post 2 of 7
Re: IntersectWith bug
01-20-2014 01:24 AM in reply to: FRFR1426
can we have the drawing too?
I guess it depends on the polyline and where the ray crosses (how close to an existing vertex).
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
7 Kudos
Post 3 of 7
01-20-2014 01:32 AM in reply to: Alfred.NESWADBA
Oh yes, I've forgotten to attach the drawing. Sorry.
7 Kudos
Post 4 of 7
01-20-2014 01:38 AM in reply to: FRFR1426
There is a vertex near the intersection. The distance is equal to 0.007 drawing units. It is a lot bigger than the precision used by AutoCAD.
7 Kudos
Post 5 of 7
01-20-2014 01:43 AM in reply to: FRFR1426
In fact, there is one intersection with the segment of the polyline where the line passes and one other with the next segment of the polyline:
*Expert Elite*
1,216 Kudos
Post 6 of 7
01-20-2014 02:00 AM in reply to: FRFR1426
- alfred -
Alfred NESWADBA
7 Kudos
Post 7 of 7
01-20-2014 02:07 AM in reply to: Alfred.NESWADBA
Yes I know. In my case, I've found another way to resolve this problem. In fact, it's the tolerance used which is too large.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
