.NET
Valued Contributor
FRFR1426
Message 1 of 7 (323 Views)
IntersectWith bug
323 Views, 6 Replies
01-20-2014 12:20 AM
A little quiz: how many intersections between this xline and this polyline?
AutoCAD answer: 3
Test code:
[CommandMethod("TESTINTERSECTWITH")]
public void TestIntersectWith()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    var peo = new PromptEntityOptions("\nSelect the Xline: ");
    peo.SetRejectMessage("\nThis entity is not an Xline.");
    peo.AddAllowedClass(typeof(Xline), true);
    PromptEntityResult per = ed.GetEntity(peo);
    if (PromptStatus.Cancel == per.Status) return;
    ObjectId xlineId = per.ObjectId;
    peo.Message = "\nSelect the polyline: ";
    peo.SetRejectMessage("\nThis entity is not a polyline.");
    peo.AddAllowedClass(typeof(Polyline), true);
    ObjectId plineId = per.ObjectId;
    using (Transaction tr = db.TransactionManager.StartTransaction())
        var xline = (Xline) tr.GetObject(xlineId, OpenMode.ForRead);
        var pline = (Polyline)tr.GetObject(plineId, OpenMode.ForRead);
        var intersections = new Point3dCollection();
        xline.IntersectWith(pline, Intersect.OnBothOperands, intersections, IntPtr.Zero, IntPtr.Zero);
        var currentSpace = (BlockTableRecord) tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
        foreach (Point3d intersection in intersections)
            var p = new DBPoint(intersection);
            currentSpace.AppendEntity(p);
            tr.AddNewlyCreatedDBObject(p, true);
        tr.Commit();
IntersectWith finds two points at the north intersection (tested on AutoCAD 2013 & 2014).
sorry to say, but I searched all the time now for a thread where I mentioned that, it's some years ago and exactly what you found out ... the extension of a segment is another intersection point (and this didn't start with 2013, it was the same issue releases earlier too).
You can now (time consuming, I know) verify each intersection point if it's on the curve or not (distance between returned intersection point and the Curve.GetClosestPointTo(xxx)).
- alfred -
Alfred.NESWADBA
Message 2 of 7 (309 Views)
Re: IntersectWith bug
01-20-2014 01:24 AM in reply to: FRFR1426
can we have the drawing too?
I guess it depends on the polyline and where the ray crosses (how close to an existing vertex).
- alfred -
Alfred NESWADBA
Valued Contributor
FRFR1426
Message 3 of 7 (304 Views)
01-20-2014 01:32 AM in reply to: Alfred.NESWADBA
Oh yes, I've forgotten to attach the drawing. Sorry.
Valued Contributor
FRFR1426
Message 4 of 7 (301 Views)
01-20-2014 01:38 AM in reply to: FRFR1426
There is a vertex near the intersection. The distance is equal to 0.007 drawing units. It is a lot bigger than the precision used by AutoCAD.
Valued Contributor
FRFR1426
Message 5 of 7 (298 Views)
01-20-2014 01:43 AM in reply to: FRFR1426
In fact, there is one intersection with the segment of the polyline where the line passes and one other with the next segment of the polyline:
Alfred.NESWADBA
Message 6 of 7 (290 Views)
01-20-2014 02:00 AM in reply to: FRFR1426
- alfred -
Alfred NESWADBA
Valued Contributor
FRFR1426
Message 7 of 7 (287 Views)
01-20-2014 02:07 AM in reply to: Alfred.NESWADBA
Yes I know. In my case, I've found another way to resolve this problem. In fact, it's the tolerance used which is too large.
