.NET
InterOp Bewilderment!
0 REPLIES 0
Message 1 of 1
131 Views, 0 Replies
I'm working on a project in vb.net that needs to automate / connect with acad versions 2000 through 2006. So as I understand it, the COM interop object is the best way to go fro the flexibility.
As I've worked along, I've built up several "references" that I'm not sure I understand:
Autodesk.AutoCAD.Interop.Common
Interop.Autocad
I'm not sure what the last one does - I don't remember adding it. Does anyone recognise it?
When viewing the references in the object browser, they seem to list
name
name&class (this is greyed out, but displays with tree)
ie:
AcadApplication
+ AcadApplicationClass (greyed out)
Why does everything have a "Class" added to it, and why is it greyed out?
thanks,
mark c.
0 REPLIES 0
”Boost
