.NET
interop Api to DotNet
5 REPLIES 5
351 Views, 5 Replies
I need to convert the commands interop.regen and
interop.zoom?????'(extent,windows,etc) with managed DOTNET equivalent.
Some help?
Thank's in advance
GPaolo
5 REPLIES 5
It is REGEN equivalent:
[code]
[ System.Security.SuppressUnmanagedCodeSecurity ]
[ DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl) ]
extern static private void ads_regen();
[/code]
NathTay
Using the .NET API.
Autodesk.AutoCAD.EditorInput.Editor.Regen()
Regards - Nathan
Thank's Nathan and for the ZOOM's serie command?
ha scritto nel messaggio
news:5348132@discussion.autodesk.com...
Using the .NET API.
Regards - Nathan
NathTay
This is what I could find in the Object Browser.
Autodesk.AutoCAD.GraphicsSystem.View.Zoom(Double)
Autodesk.AutoCAD.GraphicsSystem.View.ZoomExtents(Autodesk.AutoCAD.Geometry.Point3d, Autodesk.AutoCAD.Geometry.Point3d)
Autodesk.AutoCAD.GraphicsSystem.View.ZoomWindow(Autodesk.AutoCAD.Geometry.Point2d, Autodesk.AutoCAD.Geometry.Point2d)
Regards - Nathan
MANY THANK'S
GPAOLO
news:5348278@discussion.autodesk.com...
Regards - Nathan
”Boost
