.NET
glanard
Message 1 of 3 (236 Views)
Interop 32/64 COM - Acad Mechanical
236 Views, 2 Replies
12-12-2012 11:38 PM
Here is my sample code with the context: .Net Framework 4 / AnyCpu / ObjectArx2012:
________________________________________________________________________
Imports Autodesk.AutoCAD.Runtime
Imports SymBBAuto
Imports clsAcadApp = Autodesk.AutoCAD.ApplicationServices.Application
Public ClassClass1
<CommandMethod("TestAcadm")>
 Public Sub cmdTestAcadm()
      Dim AcadInterface As Autodesk.AutoCAD.Interop.AcadApplication
      AcadInterface =clsAcadApp.AcadApplication
  Dim SymBBInterface AsMcadSymbolBBMgr
     SymBBInterface = AcadInterface.GetInterfaceObject("SymBBAuto.McadSymbolBBMgr.3")
     MsgBox(SymBBInterface.StandardMgr.CurrentStandardName)
EndSub
<CommandMethod("TestAcadm2")>
Public Sub cmdTestAcadm2()
   Try
       Catch ex AsException
             MsgBox("Error with: <SymBBAuto.McadSymbolBBMgr.3>." & vbCr & ex.Message)
       EndTry
EndSub
End Class
  • First of all, if I add a reference to …\ObjectARX 2012\inc-win32\Autodesk.AutoCAD.Interop.dll, so this will work fine for Acad / AcadM 2012 on XP 32bits, but not on Seven 64bits.
If I replace this reference with …\ObjectARX 2012\inc-x64\Autodesk.AutoCAD.Interop.dll, this will work fine for Acad / AcadM 2012 on Seven 64bits, but not on XP 32bits.
So, my first question, do I need to create 2 solutions in Visual Studio, the first one referencing the win32 Interop and the second one referencing the x64 Interop? Isn't it possible to have only one solution for either 32 or 64 bits OS?
  • As you can see in the second Sub, the "Try-Catch" is just there to "detect" if we are on just AutoCAD (error) or AutoCAD Mechanical (no error) :smileytongue:
Is there a better solution to detect if we are really in the Mechanical Release, or to detect if the COM (here SymBB) is loaded?
Thanks a lot for your answers,
_gile
Message 2 of 3 (231 Views)
Re : Interop 32/64 COM - Acad Mechanical
12-13-2012 12:06 AM in reply to: glanard
While referencing Autodesk.AutoCAD.Interop you'll have to build two different assembly.
The only way I know to avoid this is using late binding (or dynamic type if targeting the Framework 4) where the main inconvenient is the loose of intellisense and edition/complation errors which will throw at execution time.
You can create and debug your app using Autodesk.AutoCAD.Interop reference and when it's done, replace all COM types with Object (or dynamic) type and release the Interop reference.
Gilles Chanteau
glanard
Message 3 of 3 (228 Views)
Re: Interop 32/64 COM - Acad Mechanical
12-13-2012 12:18 AM in reply to: glanard
Hi Gilles,
I suppose you're french, me too :smileyhappy:
Well, I had an idea and it seems to work^^
Referencing any of the win32 or x64 Interop, I change its property "Incorporer les types Interop" to False (and "Copie locale" to False) and my (same) DLL works fine either on XP32 or Seven 64!!
So, for me it's a good news, if anyone can confirm that there is no restriction doing this?
I know I will have to manage some things like ObjectID and ObjectID32, but this is just some "If... then...".
Edit: There is still the question: how to detect we are in "Mechanical", with the SymBB COM loaded...
