.NET
interface with Excel
4 REPLIES 4
411 Views, 4 Replies
Hi, Everyone!
I need an example source about interfacing with Excel.
Some help? Thanks in advance.
4 REPLIES 4
Start with the "Excel Developer Portal" on MSDN:
http://msdn2.microsoft.com/en-us/office/aa905411.aspx
Dan
wrote in message news:5422388@discussion.autodesk.com...
Hi, Everyone!
ahmed.felix
Here you go
' First thing, add a reference to excel object
Imports Microsoft.Office.Interop
Try
appExcel = GetObject(, "Excel.Application")
Catch ex As Exception
appExcel = New Excel.Application
xlWorkbook = appExcel.Workbooks.Add
End Try
After that everything works just like using VBA in Excel, which is another topic for another forum. The GetObject function will use an open Excel window if it finds one. Note: it will use the first one that was opened, which is the first one that appears in the processes window if you look.
Thank your for your hint.
Good Day!
Thank you for the information.
”Boost
