.NET
Installtion for ObjectARX
1 REPLY 1
kulfi
290 Views, 1 Reply
when i want to install ObjectARX i am getting this message
Can u tell me what is this message
There is a problem with this window installer package a script required for this installer to complete could not run contact your support personal or package vendor.
thanks
Kulfi
Electronics Engineer
Pind Saudi Arabia
1 REPLY 1
StephenPreston
in reply to: kulfi
I'm guessing you're seeing error code 2738. That error code translates to "Could not access VBScript run time for custom action". This is almost certainly due to the security settings on your computer. The usual remedies are:
1. Run the installer when logged in as an Admin.
2. Right click the installer and select properties; on the properties dialog, go to the Compatibility tab and set it to "Run this program in compatibility mode for:" "Previous version of Windows".
Cheers,
Stephen Preston
Autodesk Developer Network
”Boost
