.NET
Insertion Point as Object
7 REPLIES 7
Message 1 of 8
621 Views, 7 Replies
In the area *** I need to set the insertion point as Object. Dose anyone know that best way to get the user set insertion point in VB.NET
Dim acDoc As AcadDocument
Dim objBlock As AcadBlockReference
objBlock = acDoc.ModelSpace.InsertBlock(***, "c:\eq-flow.dwg", 1, 1, 1, 0)
7 REPLIES 7
Message 2 of 8
When using COM interop you might try something like:
Double point = (Double[])acDoc.Utility.GetPoint(System.Type.Missing,"Pick a point");
Be sure to trap that in a try/catch/finally block, as the user could cancel the prompt.
For interacting with the user using the managed API (much better than using COM), there are some good examples in the ObjectARX 2006 SDK. Look for prompt samples in "ObjectARX 2006\samples\dotNet\Prompts\".
Message 3 of 8
thanks for the replay It keeps telling me that the
Dim inpt As Double
inpt = (Double[])acDoc.Utility.GetPoint(System.Type.Missing,"Pick a point")
objBlock = acDoc.ModelSpace.InsertBlock(inpt, "c:\eq-flow.dwg", 1, 1, 1, 0)
it tells me that Double is an object and can't be an exprestion and that the idenifier is exspected
Message 4 of 8
Sorry, that was c# syntax that I provided. You'll need to use VB.Net's equivalent of casting.
I don't use VB.Net, but I think you might try something like this:
Dim inpt as Double()
inpt = CType(acDoc.Utility.GetPoint(System.Type.Missing,"Pick a point"), Double())
You may be able to do just this:
inpt = acDoc.Utility.GetPoint(System.Type.Missing,"Pick a point")
Be aware that you are getting back an array of doubles, not a single double as you have in your code Message was edited by: Jimmie Fulton
Message 5 of 8
egcallis
Use an Object as in
Dim inpt as Object
Try
inpt = acDoc.Utility.GetPoint(,"Pick a point")
Catch ex as Exception
' Can Put Msgbox or error checking/goto here
End
Message 6 of 8
thanks for replay, It keeps telling me that
Additional information: Object reference not set to an instance of an object.
Message 7 of 8
Here is full working code:
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Interop
Public Class Class1
Public Function test()
Dim aDoc As AcadDocument = Application.DocumentManager.MdiActiveDocument.AcadDocument
Dim input As Double()
Try
input = aDoc.Utility.GetPoint(System.Type.Missing, "\rPick a point: ")
For Each point As Double In input
System.Diagnostics.Debug.WriteLine(point.ToString())
Next
Catch
System.Diagnostics.Debug.WriteLine("Oops!")
End Try
End Function
End Class
Message 8 of 8
jayapradha
Hai
I am using the same code what is given.
but i got this error.
Dim aDoc As AcadDocument here it is giving the Exception i.e Object reference not set to an instance of an object.
Editor and Database classes also not recognizing.
for all the classes it giving the same error.
How can I rectify this error. please help to me
Public Class Class1
Try
Next
Catch
End Try
End Function
End Class
”Boost
