.NET
doum90
Message 1 of 6 (371 Views)
Inserting MText into .dwg
371 Views, 5 Replies
01-27-2013 07:41 PM
Hello everyone!
I'm trying to make a small program in vb.net that creates are laser drawing. So far I was able to create the drawing from a part in inventor. The only left to do is to add the Part Number + description into this drawing. I'm really struggling on this one. I'm currently able to open the drawing and that's all. I've tried many things from examples I found on forums but it's not working. This is a sample of what I have regarding autocad in my program:
Imports Inventor
Imports System.IO
Imports AutoCAD
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
Private Sub OpenDrawing()
Dim oACAD As New Object
Dim oMtext As AcadMText
oACAD = CreateObject("AutoCAD.Application")
oACAD.visible = True
oACAD.Documents.Open(fileNameAndPath, False)
End Sub
I need to find a way to add Mtext but I don't find anything that I'm able to use in my program. If any of you know a good reference, or have a sample of code I would really appreciate it.
as you are working from an external EXE /APP (otherwise you would not have to create the AutoCAD-object and so start the application) you only can use COM/ActiveX for communication to the AcadApplication-instance.
And as long as you use VB.NET and COM your best help might be to look to the VBA-internal help as it's quite similar (same object model). So install the VBA-Enabler (be careful, some guys have measured timing conflicts just because it is installed) and look to this help.
In case of MTEXT you'll find that:
Sub Example_AddMtext()
' This example creates an MText object in model space.
Dim MTextObj As AcadMText
Dim corner(0 To 2) As Double
Dim width As Double
Dim text As String
corner(0) = 0#: corner(1) = 10#: corner(2) = 0#
width = 10
text = "This is the text String for the mtext Object"
' Creates the mtext Object
Set MTextObj = ThisDrawing.ModelSpace.AddMText(corner, width, text)
ZoomAll
End Sub
HTH, - alfred -
here is the code I use in my vb.net program by the way:
Dim oMtext As AutoCAD.AcadMText
Dim width As Double = 10
Dim Text As String
Dim XPosition As Double = (-width / 2) + (PartLength / 2)
Dim YPosition As Double = -0.25
corner(0) = XPosition# : corner(1) = YPosition# : corner(2) = 0.0#
Text = "{\fTahoma|b0|i0|c0|p34;\L\C3DWG #" & txtNomLaser.Text & "\l\P\C3MATL: " & DescriptionPiece & "\P\C3QTY:____}"
oACAD.visible = False
lblStatus.Text = "Ouverture d'Autocad en cours..."
Retry = 0
Dim oDoc As AutoCAD.AcadDocument
oDoc = oACAD.ActiveDocument
lblStatus.Text = "Création des layers en cours..."
Dim LayerText As AutoCAD.AcadLayer = oDoc.Layers.Add("Text")
lblStatus.Text = "Ajout du texte dans le DWG en cours..."
oMtext = oDoc.ModelSpace.AddMText(corner, width, Text)
oMtext.AttachmentPoint = AcAttachmentPoint.acAttachmentPointTopCenter
oMtext.Layer = LayerText.Name.ToString
lblStatus.Text = "Sauvegarde du fichier"
oDoc.Save()
lblStatus.Text = "Fermeture d'Autocad"
oACAD.Quit()
oACAD = Nothing
Thank you very much for your help!
Alfred.NESWADBA
Message 2 of 6 (357 Views)
Re: Inserting MText into .dwg
01-28-2013 01:36 AM in reply to: doum90
    Dim width As Double
    Dim text As String
    width = 10
    ZoomAll
End Sub
HTH, - alfred -
Alfred NESWADBA
Moderator
Alexander.Rivilis
Message 3 of 6 (352 Views)
01-28-2013 01:57 AM in reply to: Alfred.NESWADBA
Hi, Alfred!
No need to install VBA Enabler in order to read AutoCAD ActiveX Documentation. It can be downloaded from http://images.autodesk.com/adsk/files/autocad_2013_activex_help.zip
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Alfred.NESWADBA
Message 4 of 6 (349 Views)
01-28-2013 02:04 AM in reply to: Alexander.Rivilis
Hi Alexander,
Much appreciated!
Where do you get that info's from?
Have you got a list of files where to download what from Autodesk? I would like to have the link to the source-code!animierte smilies lachen grinsen happy freuen smilen witzig froh
- alfred -
Alfred NESWADBA
Moderator
Alexander.Rivilis
Message 5 of 6 (348 Views)
01-28-2013 02:10 AM in reply to: Alfred.NESWADBA
alfred.neswadba wrote:
... Where do you get that info's from? ...
http://hyperpics.blogs.com/beyond_the_ui/2012/09/updated-autocad-2013-activex-developer-documentatio...
...Have you got a list of files where to download what from Autodesk? I would like to have the link to the source-code!animierte smilies lachen grinsen happy freuen smilen witzig froh
Oh! I also want a list of such files. :smileyhappy:
doum90
Message 6 of 6 (320 Views)
01-28-2013 04:49 PM in reply to: Alfred.NESWADBA
Dim Text As String
Retry = 0
oDoc.Save()
oACAD.Quit()
oACAD = Nothing
