.NET
Inserting MText into .dwg
5 REPLIES 5
doum90
1048 Views, 5 Replies
Hello everyone!
I'm trying to make a small program in vb.net that creates are laser drawing. So far I was able to create the drawing from a part in inventor. The only left to do is to add the Part Number + description into this drawing. I'm really struggling on this one. I'm currently able to open the drawing and that's all. I've tried many things from examples I found on forums but it's not working. This is a sample of what I have regarding autocad in my program:
Imports Inventor
Imports System.IO
Imports AutoCAD
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
Private Sub OpenDrawing()
Dim oACAD As New Object
Dim oMtext As AcadMText
oACAD = CreateObject("AutoCAD.Application")
oACAD.visible = True
oACAD.Documents.Open(fileNameAndPath, False)
End Sub
I need to find a way to add Mtext but I don't find anything that I'm able to use in my program. If any of you know a good reference, or have a sample of code I would really appreciate it.
5 REPLIES 5
Alfred.NESWADBA
in reply to: doum90
as you are working from an external EXE /APP (otherwise you would not have to create the AutoCAD-object and so start the application) you only can use COM/ActiveX for communication to the AcadApplication-instance.
And as long as you use VB.NET and COM your best help might be to look to the VBA-internal help as it's quite similar (same object model). So install the VBA-Enabler (be careful, some guys have measured timing conflicts just because it is installed) and look to this help.
In case of MTEXT you'll find that:
Sub Example_AddMtext()
    ' This example creates an MText object in model space.
    Dim MTextObj As AcadMText
    Dim corner(0 To 2) As Double
    Dim width As Double
    Dim text As String
    corner(0) = 0#: corner(1) = 10#: corner(2) = 0#
    width = 10
    text = "This is the text String for the mtext Object"
    ' Creates the mtext Object
    Set MTextObj = ThisDrawing.ModelSpace.AddMText(corner, width, text)
    ZoomAll
End Sub
HTH, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Hi, Alfred!
No need to install VBA Enabler in order to read AutoCAD ActiveX Documentation. It can be downloaded from http://images.autodesk.com/adsk/files/autocad_2013_activex_help.zip
Facebook | Twitter | LinkedIn
Expert Elite Member
Hi Alexander,
Much appreciated!
Where do you get that info's from?
Have you got a list of files where to download what from Autodesk? I would like to have the link to the source-code!animierte smilies lachen grinsen happy freuen smilen witzig froh
- alfred -
Alfred NESWADBA
alfred.neswadba wrote:
... Where do you get that info's from? ...
http://hyperpics.blogs.com/beyond_the_ui/2012/09/updated-autocad-2013-activex-developer-documentatio...
@Alfred.NESWADBA wrote:
...Have you got a list of files where to download what from Autodesk? I would like to have the link to the source-code!animierte smilies lachen grinsen happy freuen smilen witzig froh
Oh! I also want a list of such files. Smiley Happy
Expert Elite Member
doum90
in reply to: Alfred.NESWADBA
here is the code I use in my vb.net program by the way:
Dim oMtext As AutoCAD.AcadMText
Dim width As Double = 10
Dim Text As String
Dim XPosition As Double = (-width / 2) + (PartLength / 2)
Dim YPosition As Double = -0.25
corner(0) = XPosition# : corner(1) = YPosition# : corner(2) = 0.0#
Text = "{\fTahoma|b0|i0|c0|p34;\L\C3DWG #" & txtNomLaser.Text & "\l\P\C3MATL: " & DescriptionPiece & "\P\C3QTY:____}"
oACAD.visible = False
lblStatus.Text = "Ouverture d'Autocad en cours..."
Retry = 0
Dim oDoc As AutoCAD.AcadDocument
oDoc = oACAD.ActiveDocument
lblStatus.Text = "Création des layers en cours..."
Dim LayerText As AutoCAD.AcadLayer = oDoc.Layers.Add("Text")
lblStatus.Text = "Ajout du texte dans le DWG en cours..."
oMtext = oDoc.ModelSpace.AddMText(corner, width, Text)
oMtext.AttachmentPoint = AcAttachmentPoint.acAttachmentPointTopCenter
oMtext.Layer = LayerText.Name.ToString
lblStatus.Text = "Sauvegarde du fichier"
oDoc.Save()
lblStatus.Text = "Fermeture d'Autocad"
oACAD.Quit()
oACAD = Nothing
Thank you very much for your help!
”Boost
