.NET
Inserting blocks with VB.NET
6 REPLIES 6
756 Views, 6 Replies
Hey Everyone!
I am trying to insert blocks from a user tool with list view into drawings. I seem to be unable to do this on my own. I have looked at many listings here but are still having trouble. Can anyone help? Drag and drop help would be great too!
6 REPLIES 6
1 - Find is you insert block in model or paper space
2 - Ask to user insertion point. For this use acadDoc.Utility.GetPoint
3 - Insert block
dim objBlock as AcadBlockReference
objBlock = acadDoc.ModelSpace.InsertBlock(Insertion point, path + filename
block, X scale, Y scale, Z scale, Rotation angle)
ex.:
objBlock = acadDoc.ModelSpace.InsertBlock(InsPt,"c:\temp\test.dwg", 1, 1, 1,
0)
a écrit dans le message de news:
5086970@discussion.autodesk.com...
Hey Everyone!
would be great too!
Thanks for the replay!!!!!! what class is acadDoc Under?
dim acadApp as AutoCAD.AcadApplication
dim acadDoc as AutoCAD.AcadDocument
Is not class, is just active document of AutoCAD application but in your
reference, add AutoCAD Object Library
5087168@discussion.autodesk.com...
Heres what i've got so fare, I have lookd all thought the class view and still can't find them,
Imports Autodesk.AutoCAD
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.ApplicationServices.Document
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Colors
Imports Autodesk.AutoCAD.Windows
Imports Autodesk.AutoCAD.Windows.ToolPalette
Imports DBTransMan = Autodesk.AutoCAD.DatabaseServices.TransactionManager
Ok, I got everything exept how I define the insertion point
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
dim InsPt = ?????????????
dim InsPt as Object
Is return
InsPt(0) as X coor.
InsPt(1) as Y coor.
InsPt(2) as Z coor.
5087383@discussion.autodesk.com...
”Boost
