.NET
.NET
Valued Contributor
ProfWolfMan
Message 1 of 7 (1,410 Views)
Inserting block reference which stored in the same drawing / db
1410 Views, 6 Replies
06-05-2012 05:30 PM
Hi all,
I am trying to write a function to insert a block reference of a block definition which is already stored in the same drawing.
All threads are leads me to the way of inserting another drawing to current drawing with use of database.readdwgfile & database.insert. :smileysad:
Kindly share how to use those methods for a block definition stored in the same drawing.
Thanks & Regards,
G
Try this code for the same drawing
 Public Sub ApplyAttributes(db As Database, tr As Transaction, bref As BlockReference)
Dim btrec As BlockTableRecord = TryCast(tr.GetObject(bref.BlockTableRecord, OpenMode.ForRead), BlockTableRecord)
If btrec.HasAttributeDefinitions Then
Dim atcoll As Autodesk.AutoCAD.DatabaseServices.AttributeCollection = bref.AttributeCollection
For Each subid As ObjectId In btrec
Dim ent As Entity = DirectCast(subid.GetObject(OpenMode.ForRead), Entity)
Dim attDef As AttributeDefinition = TryCast(ent, AttributeDefinition)
If attDef IsNot Nothing Then
Dim attRef As New AttributeReference()
attRef.SetDatabaseDefaults()
attRef.SetAttributeFromBlock(attDef, bref.BlockTransform)
attRef.Position = attDef.Position.TransformBy(bref.BlockTransform)
attRef.Tag = attDef.Tag
attRef.TextString = attDef.TextString
attRef.AdjustAlignment(db)
atcoll.AppendAttribute(attRef)
tr.AddNewlyCreatedDBObject(attRef, True)
End If
Next
End If
End Sub
Public Sub TestInsert()
Dim blkname As String = "MYBLOCK" ''<-- change to your needs
Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim ed As Editor = doc.Editor
Dim db As Database = doc.Database
Try
Using docloc As DocumentLock = doc.LockDocument
Using tr As Transaction = db.TransactionManager.StartTransaction
Dim bt As BlockTable = tr.GetObject(db.BlockTableId, OpenMode.ForRead)
If Not bt.Has(blkname) Then
MsgBox("Block does not exists")
Return
End If
Dim pto As PromptPointOptions = New PromptPointOptions(vbLf + "Pick a block insertion point: ")
Dim ptres As PromptPointResult = ed.GetPoint(pto)
Dim ipt As Point3d
If ptres.Status <> PromptStatus.Cancel Then
ipt = ptres.Value
End If
Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite, False), BlockTableRecord)
Dim blk As BlockTableRecord = DirectCast(tr.GetObject(bt(blkname), OpenMode.ForRead, False), BlockTableRecord)
Dim bref As New BlockReference(ipt, blk.ObjectId)
bref.BlockUnit = UnitsValue.Millimeters''<-- change to your needs
bref.Rotation = 0
bref.ScaleFactors = New Scale3d(1.0) ''<-- change to your needs
btr.AppendEntity(bref)
tr.AddNewlyCreatedDBObject(bref, True)
ApplyAttributes(db, tr, bref)
ed.Regen()
tr.Commit()
End Using
End Using
Catch ex As System.Exception
MsgBox(ex.Message)
End Try
End Sub
~'J'~
Valued Mentor
AubelecBE
Message 2 of 7 (1,399 Views)
Re: Inserting block reference which stored in the same drawing / db
06-05-2012 10:33 PM in reply to: ProfWolfMan
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Windows
Imports Autodesk.AutoCAD.LayerManager.LayerFilter
Imports Autodesk.AutoCAD.EditorInput
Imports System.IO
Imports Autodesk.AutoCAD.Geometry
Public Class Class1
    ' Define command 'Asdkcmd1'
    <CommandMethod("ImpBloc")> _
    Public Sub ImpBloc()
        'implanter un bloc Bp
        'imp the bloc
        Dim DB As Database = HostApplicationServices.WorkingDatabase
        Dim ed As Editor
        ed = Application.DocumentManager.MdiActiveDocument.Editor
        Dim trans As Transaction
        trans = DB.TransactionManager.StartTransaction
        'récupération de la table des block
        'rep the block def.
        Dim bt As BlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForRead)
        btr = trans.GetObject(bt.Item(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
        Dim id As ObjectId
        If bt.Has("bp") Then
            'found in the  base
            Dim btrSrc As BlockTableRecord
            btrsrc=trans.GetObject(bt.Item("BP"), OpenMode.ForRead)
            id = btrSrc.Id
        Else
            'not found --> load the dwg
            Dim Dbdwg As New Database(False, True)
            Dbdwg.ReadDwgFile("d:\autocad\bloc.dwg\bp.dwg", FileOpenMode.OpenTryForReadShare, True, "")
            id = DB.Insert("bp", Dbdwg, False)
            Dbdwg.Dispose()
        End If
        'insertion :
        Dim opPt As New PromptPointOptions("Sélect a point")
        Dim resPt As PromptPointResult
        resPt = ed.GetPoint(opPt)
        Dim ptInsert As Point3d = Nothing
        Dim blkRef As BlockReference
        If resPt.Status = PromptStatus.OK Then
            ptInsert = resPt.Value
            blkRef = New BlockReference(ptInsert, id)
            btr.AppendEntity(blkRef)
            trans.AddNewlyCreatedDBObject(blkRef, True)
            ' modify the attribute of the block reference
            Dim btAttRec As BlockTableRecord
            btAttRec = trans.GetObject(id, OpenMode.ForRead)
            Dim idAtt As ObjectId
            For Each idAtt In btAttRec
                Dim ent As Entity
                ent = trans.GetObject(idAtt, OpenMode.ForRead)
                If TypeOf ent Is AttributeDefinition Then
                    attDef = CType(ent, AttributeDefinition)
                    attRef.SetAttributeFromBlock(attDef, blkRef.BlockTransform)
                    'Dim ptBase As New Point3d(blkRef.Position.X + attDef.Position.X, blkRef.Position.Y + attDef.Position.Y, blkRef.Position.Z + attDef.Position.Z)
                    'attRef.Position = ptBase
                    'attRef.Rotation = attDef.Rotation
                    'attRef.Tag = attDef.Tag
                    attRef.TextString = "input your data here"
                    'attRef.Height = attDef.Height
                    'attRef.FieldLength = attDef.FieldLength
                    Dim idTmp As ObjectId
                    idTmp = blkRef.AttributeCollection.AppendAttribute(attRef)
                    trans.AddNewlyCreatedDBObject(attRef, True)
                End If
            Next
            trans.Commit()
        Else
            MsgBox("Point introuvable !")
            trans.Abort()
        End If
    End Sub
end class
 here a example for insert a block and fill the attribut
if the block is know in the base --> insert but if not the vb.net load a file bp.dwg
Hallex
Message 3 of 7 (1,382 Views)
06-06-2012 11:38 AM in reply to: ProfWolfMan
                End If
            Next
        End If
    End Sub
        Try
                        Return
                    End If
                    Dim ipt As Point3d
                        ipt = ptres.Value
                    End If
                    bref.Rotation = 0
                    ed.Regen()
                    tr.Commit()
                End Using
            End Using
            MsgBox(ex.Message)
        End Try
    End Sub
~'J'~
Valued Contributor
ProfWolfMan
Message 4 of 7 (1,368 Views)
06-06-2012 06:13 PM in reply to: Hallex
Both answers my question. Thank you very much for your valuable time spend on this.:smileyhappy:
Now slowly i am learning dotnet .While i need one clarification on Hallex code.
Why you use "Directcast" on below lines?. If the question make any sense kindly answer.
Thanks & Regards,
G
Hallex
Message 5 of 7 (1,356 Views)
06-07-2012 01:33 AM in reply to: ProfWolfMan
Here is an excerpt from MSDN docs:Remarks
DirectCast does not use the Visual Basic run-time helper routines for conversion, so it can provide somewhat better performance than CType when converting to and from data type Object.
You use the DirectCast keyword similar to the way you use the CType Function (Visual Basic) and the TryCast Operator (Visual Basic) keyword. You supply an expression as the first argument and a type to convert it to as the second argument. DirectCast requires an inheritance or implementation relationship between the data types of the two arguments. This means that one type must inherit from or implement the other.
Errors and Failures
DirectCast generates a compiler error if it detects that no inheritance or implementation relationship exists. But the lack of a compiler error does not guarantee a successful conversion. If the desired conversion is narrowing, it could fail at run time. If this happens, the runtime throws an InvalidCastException error.
Hope it make a sense,
Cheers :smileyhappy:
~'J'~
Valued Contributor
ProfWolfMan
Message 6 of 7 (1,349 Views)
06-07-2012 02:04 AM in reply to: Hallex
Today i learned some more things.
Thank you very much for your reply.:smileyhappy:
Thanks & Regards,
G
Hallex
Message 7 of 7 (1,347 Views)
06-07-2012 02:13 AM in reply to: ProfWolfMan
Glad I could help,
Happy coding :smileyhappy:
~'J'~
