I'm trying to programatically insert a block from a pre-existing drawing into the current drawing a plugin is running on. To do that, I have a button on my C#.NET form call the following method
public void MakeAndInsertObject() //Method to add all windows and doors templates to drawing database for use later
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument; //Stores the active document
Editor ed = doc.Editor; //Stores the document's editor
Database dtb = ed.Document.Database; //Stores the database from the editor
Transaction tr = dtb.TransactionManager.StartTransaction(); //Start a transaction with the document's database
DocumentLock docLock = doc.LockDocument();
using (tr)
using (docLock)
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(dtb.CurrentSpaceId, OpenMode.ForWrite); //Opens the block table record so you can write to it
BlockTableRecord newBlockDef = new BlockTableRecord(); //Creates a new record in the block table
BlockTable blockTable = (BlockTable)tr.GetObject(dtb.BlockTableId, OpenMode.ForWrite); //Opens the block table so it can be written to
//Pointing new block to correct drawing file
newBlockDef.Name = "Door";
newBlockDef.PathName = "C:/Users/Administrator/Documents/All Code/clearspan-autocad-tools-development/Templates/locks/DOOR.dwg";
blockTable.Add(newBlockDef); //Adds the block table record to the block table
BlockReference newBlock = new BlockReference(new Point3d(0, 0, 0), newBlockDef.ObjectId); //Insert a block reference with the newly created block
btr.AppendEntity(newBlock); //Inserts the block into the current space (Model or Paper) via the block table record
//Updates the Transaction with all new database objects
tr.AddNewlyCreatedDBObject(newBlockDef, true);
tr.AddNewlyCreatedDBObject(newBlock, true);
tr.Commit(); //Applies all changes made as part of the current transaction
tr.Dispose();
The code fully executes but the block in my DOOR.dwg file does not appear at location (0, 0, 0) and I do not know why it doesn't
Solved by hgasty1001. Go to Solution.
This might help you to understand how to add and insert external blocks(drawings)
public static ObjectId AddDwg(Database db, string dwgPathname) { ObjectId dwgBlkId = ObjectId.Null; using (Transaction tr = db.TransactionManager.StartTransaction()) { BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead); string blockName = Path.GetFileNameWithoutExtension(dwgPathname); if (bt.Has(blockName)) dwgBlkId = bt[blockName]; else { if (!File.Exists(dwgPathname)) return ObjectId.Null; using (Database dwgDb = new Database(false, true)) { dwgDb.ReadDwgFile(dwgPathname, FileShare.Read, true, null); dwgDb.CloseInput(true); dwgBlkId = db.Insert(blockName, dwgDb, true); if (dwgBlkId == ObjectId.Null) return ObjectId.Null; } } tr.Commit(); } return dwgBlkId; }
/// <summary> /// InsertBlk(MsId, @"C:\x\y\BlockName.dwg",new Point3d(0,0,0),1,0); /// </summary> public static ObjectId InsertBlk(ObjectId blockTableRecordId, string blockPathName, Point3d insPnt, double insScale, double insRotation) { ObjectId blkRefId = ObjectId.Null; if (blockTableRecordId.IsNull) return ObjectId.Null; Database db = blockTableRecordId.Database; if (db == null) return ObjectId.Null; if (string.IsNullOrWhiteSpace(blockPathName)) return ObjectId.Null; ObjectId blkId = AddDwg(db, blockPathName); if (blkId.IsNull) return ObjectId.Null; using (Transaction tr = db.TransactionManager.StartTransaction()) { BlockTableRecord btr = (BlockTableRecord)tr.GetObject(blockTableRecordId, OpenMode.ForRead); BlockReference blkRef = new BlockReference(insPnt, blkId); btr.UpgradeOpen(); btr.AppendEntity(blkRef); tr.AddNewlyCreatedDBObject(blkRef, true); if (insScale != 1) blkRef.ScaleFactors = new Scale3d(insScale); if (insRotation != 0) blkRef.Rotation = insRotation; foreach (ObjectId id in btr) { DBObject obj = (DBObject)tr.GetObject(id, OpenMode.ForRead); AttributeDefinition attDef = obj as AttributeDefinition; if ((attDef != null) && (!attDef.Constant)) { using (AttributeReference attRef = new AttributeReference()) { attRef.SetAttributeFromBlock(attDef, blkRef.BlockTransform); attRef.TextString = ""; blkRef.AttributeCollection.AppendAttribute(attRef); tr.AddNewlyCreatedDBObject(attRef, true); } } } blkRefId = blkRef.ObjectId; tr.Commit(); } return blkRefId; }
Oops! the recovery of the attributes must be changed into:
BlockTableRecord newBlock = (BlockTableRecord)tr.GetObject(blkId, OpenMode.ForRead); foreach (ObjectId id in newBlock)
